90 spec ecu
Old Jun 11, 2006 | 01:14 PM
gambit's Avatar
gambit
Default 90 spec ecu
can you fit a 90 spec (hearts and diamond) ecu to a pre 90 spec loom???
Old Jun 11, 2006 | 02:12 PM
bladend's Avatar
bladend
Default 90 spec ecu
as long as the ecu is is apre 90 spec s2 model there is no difference so bassicly as long as its a series 2 ecu going to another series 2 no problem
Old Jun 11, 2006 | 03:28 PM
SafeChav's Avatar
SafeChav
With the exception of the very early S2's which don't have a knock sensor or the secondary CTS.........
Old Jun 11, 2006 | 04:23 PM
gambit's Avatar
gambit
Default 90 spec ecu
i have noticed an extra sensor on my new engine that was not on the old one the ecu came from the same car
safe chav: its coming off the air bypass valve and i think it is a cylinder head temp senor but aint sure. i have however seen the sensor on my loom but it is tied bak and was not used on my old engine. do i have to change the loom????
Old Jun 11, 2006 | 04:25 PM
gambit's Avatar
gambit
Default 90 spec ecu
by the way my car is a 87e series 2 rs turbo and the ecu came off another series 2
Old Jun 11, 2006 | 04:36 PM
SafeChav's Avatar
SafeChav
Just check to see if you have a knock sensor on your inlet manifold, if you do it will be fine
Old Jun 11, 2006 | 06:02 PM
gambit's Avatar
gambit
Default 90 spec ecu
i take it the knock sensor is the green one on the right hand side of the inlet manifold, if so then yes i have one. so you think it will be fine then???? also that extra sensor that i have on my new engine (the white one coming off the bypass valve) shall i connect it when i fit the engine. Like i said there always was a dissconnected sensor in my engine bay and that is the one for the sensor i found on the new engine that was not on my old one. I hope that makes sense.
thanks alot
Old Jun 11, 2006 | 06:48 PM
SafeChav's Avatar
SafeChav
The sensor you are talking about is on top of the auxiliary air device, and has the same shape plug as the IAT sensor and fan switch yeah?
Probably had an engine change in its life and the engine put in was an earlier one without it, connect it if you have it now.
And, yes, the ecu will be fine
Old Jun 11, 2006 | 07:40 PM
gambit's Avatar
gambit
Default 90 spec ecu
you are a safe chav lol
thanks alot mate
Old Jun 12, 2006 | 08:37 AM
SafeChav's Avatar
SafeChav
Default Re: 90 spec ecu
thanks alot mate
Obvio
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
griffo69
Oct 4, 2015 11:58 AM
stevecfrst1
Sep 30, 2015 05:18 AM
