Steering column bushes for S2
Aug 10, 2004 | 12:21 PM
Does anyone know the finis codes for the above itmes?
I think theres 4 of them in total...
Thanks in advance
Aug 10, 2004 | 12:23 PM
4 things in total
2 grey lower plastic bushes
1 white colar bush.
1 steering bearing
unsure on the parts mate, but there the 4 you should replace
Aug 10, 2004 | 12:30 PM
Cheers Ryan, how hard are they to do?
Anyone got the finis codes....?
Aug 10, 2004 | 12:41 PM
easy to do, remove steering cowels.
remove steering wheel
unplug, ignition barrel wiring.
remove barrel casing mouting.
then 4 13mm bolts to undo the column support.
that will allow you to get to the 2 lower bushes, the colar and bearing are piss easy.
Aug 10, 2004 | 12:45 PM
sweet
Job for me when I get the car back, I can lift the steering wheel up and down about 2 inches
Aug 10, 2004 | 12:46 PM
Aug 10, 2004 | 12:49 PM
6147075 top bearing Ł2.68
6187451 lower beearing Ł1.11
6133626 lower bearing Ł1.42
6130997 grommet Ł0.41
all + vat
Aug 10, 2004 | 12:50 PM
good man doo
Aug 10, 2004 | 12:55 PM
Cheers Doo, couldn't find them on Microcat
Gonna go and order myself some now
Aug 10, 2004 | 02:28 PM
just did mine today as well not too hard at all
Aug 10, 2004 | 03:40 PM
Doo where do u find the the codes have u got a list on ur puter or just an incrediable database in ur head
Aug 10, 2004 | 03:50 PM
Called Microcat - Ford parts CD - freely avaliable to be honest and does work on Windows, but wouldn't know where to find a copy
also the fact he works for Ford is handy LOL
Aug 10, 2004 | 04:05 PM
Aug 10, 2004 | 04:58 PM
Very worthwhile job!! transformed my car!
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
