Corrosion in the head / porus
Old Jun 10, 2006 | 06:26 AM
Mk2_2dr_2L_Escy's Avatar
Mk2_2dr_2L_Escy
Default Corrosion in the head / porus
Hi,
Is it common for cossie heads to get porus ??
As I took my head in to get some welding done to the combustion chamber and the fella said that the head was quite badly corroded in the water galleries.
He's now cleaned up the corrosion and found the head to be quite porus in some areas and thus he is having difficulty welding it.
What can be done in a situation such as this ? is there a special treatment that can be done to the head to solve this problem or is there a special way of welding it ?
Any advise will be greatly appreciated.
Thank you
Damion.
Old Jun 10, 2006 | 09:31 AM
Csm's Avatar
Csm
yes they are common on the cossies
id be sourcing another head for the car either second hand or really hurt the wallet with a new one
Old Jun 10, 2006 | 11:17 AM
Mk2_2dr_2L_Escy
Thanks, thats not good
Where's a good place to source a good head ??.. im in Australia unfortunately so i'd like to find someone trustworthy.. thanks.
Old Jun 10, 2006 | 11:33 AM
Csm's Avatar
Csm
better to try the trusted breakers from here first then
north yorkshire spares
petes rs specialists
Old Jun 10, 2006 | 03:52 PM
D-BO's Avatar
D-BO
as above most do go bad
Old Jun 11, 2006 | 01:14 AM
Mk2_2dr_2L_Escy
Thanks Millsy, sent both messages and north yorkshire spares got back to me and said that they are hard to come by these days..
Where can a new one be bought ? and dare i ask how much ?
Old Jun 11, 2006 | 07:48 AM
Csm's Avatar
Csm
try some of these peeps who advertise brand new heads .....
woodford motorsport on www.cosworth.info or 01803 863958 they advertise it brand new and i hope u are sitting down.... at £1450
also try www.burtonpower.co.uk 020 8554 2281 they are a brilliant company just like woodfords above !!!
think if the companys supply new heads then im sure they will all be very close to same prices buddy !!
good luck
Old Jun 11, 2006 | 09:31 AM
PAUL S's Avatar
PAUL S
Be aware that these heads are bare - just the casting only - you will have to reuse all your valves etc and your cams wont fit as the heads are the 4x4 version, so you will need a set of these as well
Old Jun 11, 2006 | 09:53 AM
Csm's Avatar
Csm
i actually forgot that
fook it vwill cost ya matey
Old Jun 11, 2006 | 10:57 AM
Mk2_2dr_2L_Escy
Yeah it's not a good position to be in at the moment i can tell you that
Thanks for the help guys..
Old Jun 11, 2006 | 12:45 PM
costina's Avatar
costina
Live long and prosper!!
Maybe a change of engine would b a better option shame
Old Jun 11, 2006 | 02:11 PM
cossiegreg1's Avatar
cossiegreg1
why not try ebay
Old Jun 11, 2006 | 11:35 PM
Mk2_2dr_2L_Escy
Change of engine isnt an option i've spent enough on this concervion and all the work is done, the engine was running in the car, just not for very long..
I thought about trying ebay, but im afraid of being caught out with another dodgy head..
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
