Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
EFI conversion bits
Old Jun 8, 2006 | 09:44 PM
TURBO BOI's Avatar
TURBO BOI
Default EFI conversion bits
im after...................
Frst turbo rocker cover and charge pipe with idle valve take off
xr3i throttle cable and pedal
beige injecters
OFAC 165 or 195 chipped ecu
Cosworth T3 cone filter with the neck
Old Jun 9, 2006 | 10:19 PM
david's Avatar
david
1.8cvh crank pulley and tps sensor + timing belt cover
I can do you all that for £50 delivered, pulley has been machined down, comes with a new Ford CPS and also a good spare. timing belt cover is already trimmed to match up with a 1.6 cover. just ready to bolt on
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
bigryrs
Sep 7, 2015 06:45 PM
liam-rst
Was It You?
Sep 5, 2015 06:38 AM
