bailey breather and air con on saff
in order to have a decent breather set up i am gonna need a new breather, prob go for pro alloy. stage 3 engine.
as i have air con and my engine bay looks like this (not actually mine but similar)
will i need a mirror image tank as with the air con pipes theres very little room for a seperator near the battery.
OR
should i junk the air con, get a seperator, and an RS500 spec intercooler, as the air con rad does block the normal rad and the engine runs hot.
note: my air con DOES work and is nice on hot summer days
any advice guys
rory
OR
any advice guys
rory
Just junk it and open a window and dont work your engine so hard. If you can, deffo go for the rs500 i/c I think they are worth there weight in gold. oil seperator is also a very good idea
when its turned on i seem to recall that the aircom sapps about 5 - 10 bhp. even when its off because of the pulleys etc its still draining some power.
i wouldnt get rid of mine though as its worth its weight in gold in this weather, especially if you've leather seats
i'd never get rid of the air con, unless it was a proper track car, and even then it's worth it to keep cool with the windows closed
anyway, there is a relay that turns it off when you hit wide open throttle so you don't need to ditch it other than for fitting the RS500 cooler
ditch the fan on the front and fit a bigger cooler there
dojj quite right. except the fan bit. if you don't have a massive electric fan putting air through the a/c condenser, the pressure will rise very high making the compreesor use more power and for the system to work very ineeficiently. the heat that you take out of the cabin air has to go out of there
the compressor has an electromagnetic clutch so it doesn't use any power when switched off (except from a fraction of 1 hp to turn the freewheeling pulley with the belt).
trust me on this, i've worked for an aircon compressor manufacturer for over 10 years
from what i've seen on the sierra/granada AC stuff the front fan is very rarely operational
but it's a fair point about the fan because it's there to cool down the regrigerant in the system when it gets too hot
it's nothing to do with temperature of the refrigerant. it changes the pressure at which the refrigerant condenses (which happens at a constant temperature)
i run a climatic wind tunnel testing automotive air conditioning day in and day out, so i know my shit on this one
i've had air con on my sierra/granadas for the past 8 years
i've never seen the fans spinning in all that time, even the ones that aren't siezed
at least 3 of them wern't and they wern't sized either
not that i'm siang they don't, i'm just saying i have't had one thats come on
i've seen them spinning on bmw's and rollers though,s o perhaps they should
Originally Posted by jason_nike
This is how they should look with the aircon.
Originally Posted by JTECHSAFF
that pipe should go into the air filter, but sends oil into the air flow ,so people disconnect it rather than using a proper oil seperator
pro-alloy mirror image breather on its way very soon
no air box, just a cone filter
current set up breathes the flame trap, to little filter above the throttle and throws oil EVERYWHERE
ideally would buy a normal seperator but no room due to the air con
you may be able to squeze a normall one in there somewhere, make a braket and mount it off the battery tray, but the mirror image is the best option, get a fitting kit too so you get all the atachments to the block and r/c
