Big electric broblems in my Sapph
My Sapph project is nearly finished but I have big broblems with electrics. Today I connect the battery. The central lock system started immediately to lock and unlock the doors. It didin't stop untill I disconnect the battery or unplug the central locking. Whats wrong with central locking? Central locking is from -91 cossie. My doors are delocked and the original alarms wires from central lockin to doors keylock is also removed.
The indicators didin't eather work, cauges alarm lights didin't work etc... Whole electric system seems to be messed up.
Only thing which seemed to work proberly was the lights inside the car.
If one of the motors stops working it affects the whole system, if you re-connect your battery look at the doors and see which one is not locking/unlocking. You also get this problem if one of the doors is open, trying closing all the doors and reconnecting the battery (leave a window open in case the doors lock and you can't unlock them from the outside).
As to the other problems check your fuses are all OK and the earth points, and also check the items are conected correctly. I recently had trouble with the fuel pump not coming on and it turns out that if the rear light boards aren't connected the pump fails to work, seems a bit wierd but it looks like the earth runs through these.
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
