coil differences and ignition module?
Old Aug 9, 2004 | 10:45 PM
Hofajoab's Avatar
Hofajoab
Default coil differences and ignition module?
say i had a 2.0 DOHC efi working corectly and i put the coil from the 1.8CVH (carb) in it would cause any problem?
i mean would it cause the ECU relay not to activate when the ignition is on?
or if the rev counter (green wire, pin 11 on instrument cluster) wasn't on would that cause it?
OR
if the ignition module was goosed would that cause the realay not to switch? (Relay XI) the main ECU relay.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
