Best 2wd coilover suspension ??
Old Jun 5, 2006 | 01:08 PM
Ridgey's Avatar
Ridgey
Default Best 2wd coilover suspension ??
Just decided that i will be replacing the suspension on my Saff with coilovers (occasional road and trackday car).
Does anyone else out there have coilovers on a 2wd Saff, if so whats the best make, AVO, SPAX, GAZ. Looking for a quality product that will LAST.
All opinions appreciated, as well as the new suspension the car will be getting Adj TCA's and is already polybushed including suspension top mounts, bolt in roll cage and fully stripped.
cheers
Dave
Old Jun 5, 2006 | 03:00 PM
costina's Avatar
costina
Live long and prosper!!
Avo had gaz tend to rust easy
Old Jun 5, 2006 | 03:07 PM
Ridgey's Avatar
Ridgey
Costina
Did you have any problems fitting the rear ones up into the turrets. Heard that some are a squeeze/impossible ?
Do you know what the spring rates are on them?
Old Jun 5, 2006 | 07:10 PM
costina's Avatar
costina
Lhs rear u have to bash(large ball pain hammer) an area 3" by 4" approx only to fit as the spring rubs. etch prime and underbody .
Job done
Old Jun 6, 2006 | 11:58 AM
STUCOS's Avatar
STUCOS
If you can afford it ,buy a set of billies for it,dont bother with polly top mounts just get a set of 909 top spherical bearing top mounts
cheeRS stu
Old Jun 6, 2006 | 02:56 PM
wildheart's Avatar
wildheart
Avo's rust just as bad as Gaz!
I'd be having a word with Mike Rainbird and see what he recomends and he can spec spring rates for your application
Old Jun 6, 2006 | 03:32 PM
Ridgey's Avatar
Ridgey
So by the sounds of it all coilovers suffer from corrosion.
Making me think twice about them at all, and go for suspension kit and turn dampers on to MAX setting !!!!!
Old Jun 6, 2006 | 11:33 PM
wildheart's Avatar
wildheart
I think some of the better coilovers are plated to help against rust.
Or you could just copper grease the threads on a regular basis.
Old Jun 7, 2006 | 11:33 AM
Sticky.'s Avatar
Sticky.
Most suspension dampers will rust if there left out in all weathers.
If your going to buy Coilovers speaker to Matt Lewis he does AVO's at a cracking price.
Old Jun 8, 2006 | 05:26 AM
MARCOSWORTH's Avatar
MARCOSWORTH
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
Old Jun 8, 2006 | 07:35 AM
Sticky.'s Avatar
Sticky.
Speak to him direct and you'll get them a little bit cheaper
Old Jun 8, 2006 | 09:59 PM
Basky's Avatar
Basky
i run 909 billies and people say it handles better than a 4x4 on track
thats tarmac spec
but marco runs his on the road and he says gravel spec as the tarmac ones are to harsh on the road
Old Jun 8, 2006 | 11:20 PM
Ryan's Avatar
Ryan
he runs gravel rears and soft tarmac fronts.
same as i do.
Old Jun 9, 2006 | 12:50 AM
wildheart's Avatar
wildheart
Arent Billies a nightmare to get hold of now though?
Old Jun 9, 2006 | 06:45 PM
Tangodeltasierra3's Avatar
Tangodeltasierra3
So if you fit Coilovers on a 3dr how much do most people drop em ? 30mm ? Whats max drop 60mm ?
Old Jun 9, 2006 | 08:38 PM
cosrep's Avatar
cosrep
I heard you need to weld in reinforcing plates in cossies when fitting coilovers is this true?
Old Jun 9, 2006 | 09:43 PM
rinus_2005's Avatar
rinus_2005
It wouldn't hurt, tough i know a trackday saph wich has been running stiffass gpn bilsteins (coilover and spherical bearings) for over 8years without a rear strutbrace or reionforcements in the back. No deformormations/cracks/rips to see.
Old Jun 12, 2006 | 09:30 AM
Ridgey's Avatar
Ridgey
I spoke to AVO, and they don't recon you need any strengthening, but you do have to hammer some of the inner wing at the rear for clearance of the spring.
I'm still unsure what i'm gonna do ???
Old Jun 12, 2006 | 05:16 PM
Basky's Avatar
Basky
its because its doubled skinned.
not that much of an issue when they are rose jointed, spacer the bottom of coilover away from body
Basky's Avatar
Basky
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
