Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Aftermarket cams
Old Jun 4, 2006 | 09:00 PM
E500 TAT's Avatar
E500 TAT
Default Aftermarket cams
Has anyone on here had any aftermarket cams fitted to a 1700 puma?
Do they do away with the VVT system?
I have throttle bodies and an aftermarket exhaust manifold (same spec as milltek), no cat, P/S or air con, this i hope is the next step.
What sort of gains could i expect?
Old Aug 22, 2006 | 10:43 PM
Irishfella's Avatar
Irishfella
Looking similar info myself
Old Sep 8, 2006 | 08:52 PM
Wardy257's Avatar
Wardy257
They are available, but you need an aftermarket ECU to get the best out of them. You can chose wether or not to keep the VCT.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
