Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
HELP!! Quick MK2 Escort Diff Question!!!!!
Old Jun 3, 2006 | 03:39 PM
mentalasanything's Avatar
mentalasanything
Default HELP!! Quick MK2 Escort Diff Question!!!!!
I need an answer PDQ. Does anyone know if the rear diffs on a MK2 escort are diferent?? is the 1.3 diff strong enough to cope with a larger engines power????
Lee
Old Jun 3, 2006 | 07:21 PM
puddy's Avatar
puddy
All mk2 diffs are the same,its only the ratio's that are different.
If you are going big pinto or x flow power ,then buy an lsd for it.
If you are going for cossie power,its best to fit an Atlas type axle out of a
capri,although this will need to be narrowed,and a slipper fitted also.
puddy
Old Jun 4, 2006 | 06:50 PM
mentalasanything
Cheers mate,
Lee
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
