abs
Old Jun 3, 2006 | 02:29 PM
natehall's Avatar
natehall
Default abs
guys
anyone have a clue which way round the abs brake lines go on a saph? non cossie!
also which bits of the valveblock go where - i know the middle one goes to the rears - but the other two im not sure about
thanks
nate
Old Jun 3, 2006 | 05:01 PM
dojj's Avatar
dojj
Resident Wrestling Legend
from what i can remember, you need to make sure the ones out of the master cylnder are the same as theones going from the valave block
it's not just a case of "this pipe goes there and this goes there"
you need to make sure you aren't crossing them over
there are also possible issues with getting the air lock out of the valve block
i'll go and have a look at which pipe goes where, they might even have different sized fittings
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
