anyone got one fitted on a s1 with the twin fan set up?? as im gonna order mine and need to alter the front panel to take twin fans, need to see any pics of them fitted if anyone can help?
or should i stick with just one fan??
cheers peeps didnt think anyone had replied to this
yeah i dont want to cut the whole front out really if it can be helped, just want to cut out the remainder of the lip were the original fan cut out is to were the front grill mounting brackets are, see if this gives enough space?
might go for one fan first see what temps are like
How do you get it to mount up properly? Ive cut my front panel out, and not quite as wide as yours and all the metal that the bottom clips attach to is no longer there? Or do you rely on the top clips only?
