cosworth parts UPDATED 12.6.06
pair rear 1/4 glass 80 pounds
7 1/2 " rear diff with escort drive shaft flanges , fully overhauld, 450 pounds
GPA 3 door rear bearing carriers, to take GPA flanges and fit to your std rear arms,, POA
3 door rear brake valve 85 pounds like new
7 x 15" OZ TH wheels 55 pounds each
cosworth engineclubman GPA, fully rebuilt, with motorsport 200 long studded block, WRC head gasket, BD14 cams, WRC 8 injector inlet manifold and fuel rail, New motorsport turbo, high torque exhaust manifold, high pressure oil pump with oil spray system, lightened and balanced crank, new water pump, big wing baffled alloy sump, motorsport cam belt, New anti pump cam followers, Aero spec oil hoses, lightened and balanced fly wheel, AP paddle clutch , all new seals and bearings, 6800 pounds SOLD
[img]
[/img]
[img]
[/img]
3dr cossie
11
Dec 21, 2015 03:38 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
