Removing Idle Speed Controll Valve
Old Jun 2, 2006 | 09:16 AM
James_RScos's Avatar
James_RScos
Default Removing Idle Speed Controll Valve
OK a really silly one im i missing something, I removed the two screws and pulled the plate off that holds it in plate but it still wont come away from the trotle body is there anything im missing.
Old Jun 2, 2006 | 11:41 AM
jon@work's Avatar
jon@work
No - just pull/wobble away - eventually it will come out. There is a small pin in the housing so it can't spin round, so just struggle for 5 mins and it will be out. Don't try to pry it out - the throttle body is pretty soft and you'll mark it.
Old Jun 2, 2006 | 11:59 AM
James_RScos
Ok cheers Jon will have another go tomorrow
Out of interest where in nottingham are you from ???? im from lowdham
Old Jun 2, 2006 | 01:53 PM
KSA-Cossie's Avatar
KSA-Cossie
As said above m8 give it a bit of a wiggle it will come loose.
Old Jun 2, 2006 | 01:57 PM
James_RScos
Cheers kev,
when i was trying to get it off last weekend i was on it for ages wiggling and pulling but it just didnt want to go will try it again this weekend would a bit of WD40 be ok on it to if i wanted?????
Old Jun 2, 2006 | 02:10 PM
KSA-Cossie's Avatar
KSA-Cossie
Yeah that would be ok.
Old Jun 2, 2006 | 06:16 PM
jon@work's Avatar
jon@work
Miles away mate - Wollaton
Sheepdisease
Aug 30, 2015 09:11 PM
Aug 29, 2015 08:16 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Zoggon
Aug 10, 2015 10:39 AM
