My Power s2
Old Jun 1, 2006 | 07:45 PM
RST Ski's Avatar
RST Ski
Default My Power s2
when i bought my S2 the chap said it was set back to 132bhp @ 11.6psi this sound right?? isnt 132bhp standard but 11.6psi isnt standard boost?
Old Jun 1, 2006 | 07:54 PM
AndyRST's Avatar
AndyRST
are you sure its 11.6 psi ??? I mean it could be 11.7psi or even 11.5 psi
Old Jun 1, 2006 | 07:57 PM
petermintrst's Avatar
petermintrst
i think 9psi is standard and 132bhp
Old Jun 1, 2006 | 07:58 PM
kiddie's Avatar
kiddie
Is it atw power? also do u have a boost guage?
Old Jun 1, 2006 | 08:00 PM
RST Ski's Avatar
RST Ski
just took the boost guage out, i have rolling road print outs, will the boost be on the print out?? was done at sanspeed
Old Jun 1, 2006 | 08:08 PM
notSteveS2's Avatar
notSteveS2
may b...
standard boost is 7 or 9 psi...
as above... was it 132bhp at the wheels or flywheel?
Old Jun 1, 2006 | 08:13 PM
RST Ski's Avatar
RST Ski
not sure if its at the wheels chaps, i havnt had the rolling road done since i owned it, i was given the graphs when i bought it
how do i read the power graphs? is the speed along the bottom? and the power along the side?
Old Jun 1, 2006 | 08:18 PM
notSteveS2's Avatar
notSteveS2
normally have revs along bottom... power at side...
shud have 3 lines or more if @wheels and @flywheel read out...
coloured different...
other 1 will b torque...
how many lines on the graph?
Old Jun 1, 2006 | 08:21 PM
RST Ski's Avatar
RST Ski
think i can make out about 5 lines, there all black
Old Jun 1, 2006 | 08:27 PM
RST Ski's Avatar
RST Ski
soz bout poor quality pic, done on my fone, just about read it
Old Jun 1, 2006 | 08:30 PM
Rab's Avatar
Rab
Fucking superstar........
Power is in KW. Not BHP?
Old Jun 1, 2006 | 08:31 PM
notSteveS2's Avatar
notSteveS2
sorry mate... i cant make head or tail of that... lol
anyway if at 11psi....it makes 132bhp... if thats at the wheels then it wud prob b bout 170bhp ish.... at flywheel...
which is believable... if its 132 at 11psi at flywheel... sumthings wrong there...
wot spec is it mate???
mods etc?
wud only need a chipped ecu and -31 and few other minor mods to get 170bhp
Old Jun 1, 2006 | 08:33 PM
RST Ski's Avatar
RST Ski
thats what i thought and along the bottom its km/h. wierd
Old Jun 1, 2006 | 08:35 PM
RST Ski's Avatar
RST Ski
mods etc?
my mods are filter, mongoose zorst, -31 and chip.
Old Jun 1, 2006 | 08:40 PM
notSteveS2's Avatar
notSteveS2
my guess with those mods at 11 psi set up well...
car may make like... 160bhp
if u wanna find out u gonna need to put it on rollers matey
Old Jun 1, 2006 | 08:45 PM
RST Ski's Avatar
RST Ski
the bloke owned it before reckons he had it at 150bhp at sometime before but had it reset to 132bhp drive to work or sum bullshite.
i wana get a fmic anyway so il get it set up then
do i have to use same rolling road if the chip was fitted there?
Old Jun 1, 2006 | 08:50 PM
notSteveS2's Avatar
notSteveS2
no matey... go where u want to... chip is just to de restrict ecu really...
get a GRS matey...
good man for gettin 1.....
Old Jun 1, 2006 | 08:53 PM
RST Ski's Avatar
RST Ski
cheers for the advice n input guys GRS easy to fit? will i need new boost hoses?
Old Jun 1, 2006 | 08:59 PM
notSteveS2's Avatar
notSteveS2
no new boost hoses.... yes very easy to fit....
al ull need to do is sort out new fan situation...
easiest option is twin 10' kenlowes... but expensive...
wen i fitted mine... i lifted up rad to run wires behind it... allowing GRS to push up close to rad leaving more space for fan... then fixed rad bk down... just push it in place... obviously u gotta remove std cooler first...
then fit a bracket ,which takes place of old cooler, to rad...
they cum with 4 tabs welded to it to bend how u want them so u can drill em out and fix bolts thru existing holes in front end...
JanoOddkidd can supply ya 1 i think matey... www.oddkiddcreations.co.uk
just ask...
really easy mate...
Old Jun 1, 2006 | 09:13 PM
RST Ski's Avatar
RST Ski
nice 1
Old Jun 1, 2006 | 09:19 PM
notSteveS2's Avatar
notSteveS2
Old Jun 1, 2006 | 09:24 PM
T28 RST's Avatar
T28 RST
Ok then
Get it set up as then you will have a true reading and also have peace of mind that its ok
Old Jun 2, 2006 | 09:10 AM
ivorbiggun's Avatar
ivorbiggun
132 at wheels = 155 at crank.
The above looks like someones been using their etchasketch.
I'm looking at all my graphs(many different companies) and none of them
feature wheel and crank, all of them are crank only.
Don't mess around guessing, take it to someone like Jamie at Jamsport
spend your Ł140 having it set up correctly and you'll have to worry
about 2 less things...
1,Is it/when will it go bang?
2,So, thats how much it produces......!
Good luck
Old Jun 2, 2006 | 09:37 PM
notSteveS2's Avatar
notSteveS2
Good luck
never been to EA then i guess...
yea gettin a gd set up is the way forward...
but if u r curious of power... need to be rollered...
Old Jun 2, 2006 | 11:09 PM
Andy_R's Avatar
Andy_R
132killowatts is equal to 177hp, if your planning on fitting a larger capacity intercooler then its worth your while having your car setup once its fitted.
Old Jun 3, 2006 | 09:20 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Spal fans will do the job also. that's what I'm gonna get I think. And a lot cheaper for similar spec
Old Jun 3, 2006 | 09:53 AM
DanRSturbo's Avatar
DanRSturbo
Are they in Dartford ??
Mine made 155 @ Power Engineering on 10psi
You'll need to get it setup properly by a good tuner
Old Jun 3, 2006 | 11:08 AM
RST Ski's Avatar
RST Ski
sanspeed is in bexleyheath, duno wot there like
Old Jun 3, 2006 | 11:25 AM
Rab's Avatar
Rab
It is reading in KW. Which is like Andy says 176.8 bhp. So, nothing to worry about IF thats a real graph. But, I'm with everyone else. Take it to a reputable tuner and get it set up properly
Old Jun 3, 2006 | 07:14 PM
RST Ski's Avatar
RST Ski
on the top right hand of the graph (just about see it) the tuner has hand written 132bhp? duno y the sheat is in kw.
sod it, ill have it checked after i fit me fmic anyway chaps
Old Jun 5, 2006 | 02:47 PM
RST Ski's Avatar
RST Ski
Right now chaps, i was reading over my advert for my car from when i bought it from ebay in november (saved in my favorites)
and in the list of the car mods, it lists actuator, exhaust, filter, dump valve
but no mention of ecu chip?
he said he had it running at 150bhp at one time so its not possible to run this bhp without a chip? or is it?
is there a way of seeing if my ecu is chipped? stickers ect?
Old Jun 5, 2006 | 02:53 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Avoid.....
Old Jun 5, 2006 | 02:55 PM
RST Ski's Avatar
RST Ski
was dreading that!!
Tony Turbo's Avatar
Tony Turbo
My original engine made over 150bhp @ 10psi without a chip. It can be done. You be best off getting an intercooler and a chip and you be on your way to a good 200bhp.
Old Jun 5, 2006 | 03:01 PM
RST Ski's Avatar
RST Ski
i got a strong feeling mines not chipped with you posting that tony, can i just buy a chipped ecu and then get it mapped, or shall i get it chipped at a good tuner? (after i get a intercooler)
Old Jun 5, 2006 | 03:07 PM
Tony Turbo's Avatar
Tony Turbo
Depends, chips vary very little. Most off the shelf chips will be fine for 99% of MFi users. Buying a second hand ECU with a "chip" in it would be the cheapest way of doing it. Then you can just swap the ECU's over and drive to a tuner and get them to set it up. It only takes 10 minutes to swap the ECU's over.
All an RST chip does is remove the boost cut. It will have an ignition curve written into it too. There is no "mapping" as such, just some tweaking with some screws to get the fueling as right as possible.
Old Jun 5, 2006 | 03:29 PM
RST Ski's Avatar
RST Ski
i think il go the 2nd hand ecu chip route, any chips better than others? whats hearts and diamonds? a make of chip?
would i be ok to drive around for a bit on another ecu which wasnt chipped for my car if i dont go mad?
Old Jun 5, 2006 | 03:32 PM
Tony Turbo's Avatar
Tony Turbo
What ECU you have the moment? The best ECU for an RST is a S1 ECU. Blue Red Blue I think...
Make of chip doesn't really matter, like I said there is very little difference. You could fit the chipped ECU and drive as normal. It wouldn't alter the fueling at all.
Boy, all this talk of ECU's and Chips bring back memories
Old Jun 5, 2006 | 03:42 PM
RST Ski's Avatar
RST Ski
apreciacte the advise
the colours on mine are blue/red/black whats that?
Old Jun 5, 2006 | 03:48 PM
Tony Turbo's Avatar
Tony Turbo
No problemo
1988?
