Loads of 2wd parts and ECU P8 SECs
Old Jun 1, 2006 | 12:24 PM
RS500/364's Avatar
RS500/364
Default Loads of 2wd parts and ECU P8 SECs
offers on bold stuff
Ratchet & Paw Heavy duty (NEW) for clutch from ford on box
8 Platinum Spark Plugs (New) AGPR 902P new and boxed
Side Repeaters (USED)
Wheel Bearing Kit (NEW) EUB 57 / 58
Brake Pads (OLD BUT NEW)
Rear light clusters (Used)
Front indicator lenses / clear (Used)
PM offers from the above will do pics soon
P8 ECU IN L1 CASE FOR THE RS500
WORKING FINE STANDARD
£350 inc p+p
can fit into p8 case at but would prefer to leave in l1 case checked by ahmed !!
OR WITH NEW BABY BOARD AND CHIP TO RUN GREENS £450 or £145 board and chip NEW
BOARD ALONE COST £350
KONI 2WD FRONT WITH SRPRINGS AND REAR DO HAVE SOME SPRING IF NEEDED £100 INC P+P
auto meter air mixture without lamba with box and paper work
with boost with pipe and fittings on gauge +/1 30psi no bulb white face orange needle was held in by double sided tape cant find the bracket
the pair
£50 £59 with p+p
water temp and oil pressure
need temp adaptor fitted and brackets
with matching boost -15 to +30 psi
white face black needle
£40 £45inc p+p
3 door twin pod for a post £20 inc p+p
full saff interior with everything dash pastics shelf £150
moonstone standard bonet £30
also standard 4x4 shocks £50 or offers replaced for konis
ALSO
FORD ECU OUT OF A 2L SIERRA TWIN CAM OFFER
SECs ECU should be back tomo £380 + P+P
Old Jun 1, 2006 | 01:33 PM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
how much for the plugs and air mixture gauge?
Old Jun 1, 2006 | 06:18 PM
RS500/364's Avatar
RS500/364
the air mixture is priced with the boost
so make and offer for all !!
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Bailes1992
Aug 16, 2015 07:14 PM
155lee
Aug 14, 2015 11:21 AM
RsS2daz
Aug 14, 2015 05:26 AM
