cosworth loom
Old May 30, 2006 | 05:05 PM
philcab's Avatar
philcab
Default cosworth loom
hi iam fitting cossie managment to me my escort rs turbo and was wantin to know if any one and an diagram so i get fit my level 6 loom. cheers
Old May 30, 2006 | 05:07 PM
philcab's Avatar
philcab
dirgram to fit my loom to my escort cheers.
Old May 30, 2006 | 07:53 PM
DazC's Avatar
DazC
You should only have 5 wires to connect mate...
Red/Blue needs a fused battery live feed.
Black/Red is the feed to the fuel pump.
Black is an ignition live.
There are then 2 green wires IIRC and those are for the coolant temperature guage and the oil pressure warning lamp. I can't remember which way round they are but if you look at the wires at the plug ends, you will be able to determine which is which.
Old May 30, 2006 | 11:38 PM
tim10_10's Avatar
tim10_10
one of the greens is a rev counter and i thought 2 of the blacks were earth but may be wrong on the earth side.
big_Rad
Sep 15, 2017 09:36 AM
muz
Aug 16, 2015 12:57 PM
Aug 14, 2015 07:29 AM
gingerturbo
Aug 11, 2015 09:44 PM
jdsjojo
Aug 1, 2015 08:50 PM
