uprated cam in standard head
Old May 30, 2006 | 03:55 PM
320 bhp's Avatar
320 bhp
Default uprated cam in standard head
if i put uprated cam in my rebuilt standard head with a set of adjustable pulleys would it make any difference or will it need port/polish??
Old May 30, 2006 | 04:47 PM
righthooker's Avatar
righthooker
will make a diference ,what cams you thinking of though?
Old May 30, 2006 | 04:53 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Also make sure there not too big or you will need pocketed pistons too
Old May 30, 2006 | 04:56 PM
320 bhp's Avatar
320 bhp
fancy some bd10 or sumthg what do u sujest,will have low comp pistons lightened/balenced bottom end t34,stage3 rs500 cooler what bhp should i be looking at
Old May 30, 2006 | 05:01 PM
NUTTIN RILLA
Shouldnt be that far from 350 mate depending on who sets it up and how much boost your gony run, expect around 330/340 reliably
Old May 30, 2006 | 05:11 PM
320 bhp's Avatar
320 bhp
THAT WILL BE ME FINE AS LONG AS ITS RELIABLE HOW GOOD IS THE 205 BLOCK???
Old May 30, 2006 | 05:17 PM
NUTTIN RILLA
The key to reliabality is to treat it right with plent of service`s, a 205 block should be fine mate, theres plent of them seen 450 plus with no trouble
Old May 30, 2006 | 05:20 PM
320 bhp's Avatar
320 bhp
THAT OK DNT WORRY ALWAYS SERVICE ME COSSIES EVERY 2-3 MILES AND REGULAR TUNE UPS WILL KEEP YA POSTED ON THE BUILD THANX
Old May 30, 2006 | 05:21 PM
NUTTIN RILLA
No sweat mate
Old Jun 2, 2006 | 07:59 PM
choppa's Avatar
choppa
if you fit the better cam in the standard head youll find that the airflow through the head ports will be faster than that of the modified ported head. thus giving you beter drivability and economy. the larger ports will reduce air speed and improve air flow, encouraging the fuel the form droplets. this doesnt matter when your revving the cock off it because the fuel will vapourise properly but at low speeds it wont be as efficient.
RUBY123
Oct 22, 2023 12:04 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
mint_s2
Sep 2, 2015 08:58 AM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
