ZVH Proplems again.... well still the same.
Old May 30, 2006 | 03:09 PM
Gregor's Avatar
Gregor
Default ZVH Proplems again.... well still the same.
Hello,
I posted a tread a while ago about my zvh engine smoking verry much with white smoke ( water )...
Since then 1 skimmed the head and pressure tested it... it was fine...
Put everything together with new felpro head gasket and new cougar headbolts... all the other gaskets were also new but stil i have the smoking goning on.....
Had the turbo coolant blocked off but without result....
What else could be wrong.... block not flat or a crack in the cilinder ..
think i'll have to pressure test the zetec block as wel then...
thanx
Thanx again...
Old May 30, 2006 | 03:29 PM
320 bhp's Avatar
320 bhp
sounds like cracked bore
Old May 30, 2006 | 04:47 PM
ivorbiggun's Avatar
ivorbiggun
If it's a 2 litre your building take a look at www.quantums.info/zvh.htm
Jim explains about the oil/water ways being very close together and what to do about it. Good Luck
Old May 30, 2006 | 05:13 PM
Gregor's Avatar
Gregor
Yess it's a 2 liter... but it's not the same as on that site.. ( already got that site in my favorites :P )
There are no water/oil ways close together... checked it again when i replaced the gasket yesterday....
Old May 30, 2006 | 05:59 PM
Mr.T's Avatar
Mr.T
Hi mate. Just buy my car. It is cheap and runs without using any fuel hehe
Old May 30, 2006 | 07:56 PM
DazC's Avatar
DazC
I'd throw it away and stick the 1600 CVH back in!!!
The Felpro gasket won't be helping matters either!!
mk1turboestate
Dec 2, 2015 08:31 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
SMILER258
Sep 28, 2015 09:04 AM
davidfordrs
Sep 21, 2015 04:23 AM
