efi flywheel positioning
on the back of the efi flywheels uve got the recesses in the flywheel for the crank position sensor but 1 of them is larger than the others,which way has the flywheel got 2 b positioned on the crank for the correct timing
The flywheel will only go one in one position, the bolt holes are delibarately offset so that it can only be fitted in the correct position.
Lincolndanny: would you like a picture of that sir?????
