intercooler
Old May 28, 2006 | 04:58 PM
RST Ski's Avatar
RST Ski
Default intercooler
if i fit a front mount ic will it give me a bhp gain with out a set up, if so how much can be expect?
i no it sounds silly but jus woundering if i would notice a power gain by jus bolting one on. (but i no its does need to be set up correctly for good power gain)
Old May 28, 2006 | 06:58 PM
Micky's Avatar
Micky
Nope.And youre correct,it does ned to be set up after the cooler is fitted.So dont be giving it a heavy right foot till after the set up.Regards Micky
Old May 28, 2006 | 11:35 PM
Andy_R's Avatar
Andy_R
You'll likely find that there is an increase in boost 2-3psi isnt uncommon. Its definatly worth having your car set up after uprating your intercooler. To ensure it isnt runnig lean and to prevent destroying your engine.
Old May 29, 2006 | 12:04 AM
JimmyBoy's Avatar
JimmyBoy
I think you would see an increase in bhp, but comes down to how much boost you are currently running on standard ic. If you are using say 18+ psi on standard cooler, then you will deffinately see an increase in bhp because the ACT's on the standard ic will be soooooo high! lol
Old May 30, 2006 | 10:46 PM
notSteveS2's Avatar
notSteveS2
lol... as above... may see increase in torque too
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
