Cossie parts, Edited 11-11-06
See new forsale threads. EDITED 11-11-06
rs500 inlet complete.
https://passionford.com/forum/viewto...921&highlight=
P8 super 8 ecu and sub loom.
https://passionford.com/forum/viewforum.php?f=48
Other cossie parts.
https://passionford.com/forum/viewto...922&highlight=
RST parts..
https://passionford.com/forum/viewto...916&highlight=
Other cossie parts.
RST parts..
Originally Posted by 3dr wixsy
What exactly does the fitting kit for this pump consist of, where do you get them from, let me know and ill have the pump, regards Tony
The kit comes with a m18 male thread, with a 15mm hose end. Which is normally £20 -25. I have the kit, and will do the lot posted for £160
Hi Dan ,
Would you consider selling the modded plenum cover on its own , it may be this thats putting people off the whole kit but its not an issue to me , i have all the rest of the bits already .
Just a thought and fully undersatnd if you dont .
Tony
Tony
Originally Posted by Tony Ryan
Hi Dan ,
Tony
Tony
I'm willing to split if i had people intrested in the major parts,
But this is because its still on the car, and will be till its sold.
Wot do you want, the plenum on its own?
Originally Posted by AndyR1
hello ,if tony as the modded cover,then i will have the throttle bracket and one set of the greens,if you do split it ,cheers andy
Tony hasn't come back, so not gonna split @ mo, but things might change.
But i'll split the greens if you want a set.
Originally Posted by adamski frst
dan let me know when you have the head off your rst i might have it off you how mcuh you want for it ??? pm me!?
I need to find a decent flowed RST hemi head 1st, then it will be coming off.
Tony, recieved your pm
Originally Posted by cossy nav
fiesta cossie
so if i buy it all i need is head gasket and it skimmed
it came off my Fiecos when i went big power, and the whole engine/turbo set up never smoked. and that was @ stg3..
P8 super ecu up for grabs.
It comes with sub loom and ecu, and chip from my Fiecos, inc GT30, 8 x 803's, rs500 inlet. Made 505bhp and 447lbft on a engine dyno. and run 4 x 11.1s@124mph.
£670 posted
£670 posted
