FIESTA RS1800 SUPERCHARGER
I dont know if this is done befor but i decide to put roots type of supercharger in my Fiesta RS1800. It was a lot of work to do but im hapy with tesults. So my englis language is not so good so there is some pictures and video for you.
An a year ago i built first custom hedaer for my fiesta but i have in my mind to design it for my aplications....
custom header:
then I buy this stuff:
Eaton M62 (roots kompresor)
injectors
throtle body
IC
megasquirt
And then start with...
work progres 1
work progres 2
built custom intake:
finished ic
drive extenzion
end picture
And finaly first test day at only 3 psi but car is quite fast...video
http://www.mobisux.com/album/data/500/20483Fiesta.wmv
custom header:
injectors
throtle body
IC
megasquirt
work progres 1
work progres 2
finished ic
drive extenzion
end picture
i cant believe my eyes! you have done almost excactly what i had planned for my 1.8 xr2. only i have a bigger supercharger from an airoplane. i cant do it now cos i had to get rid of the car. how did you get the driveshaft mounted? is the charger mounted to the wing? how did you take up the slack in the drive belt? (the engine moves on acceleration). i cant big you up enough mate! i fuckin love it! well done!!!
Thats an excellent piece of work
I believe this kit will bolt straight onto the 1.8 in the Fiesta too.
http://www.jacksonracing.com/Shop/Vi...eIndexID=47906
I know it works on the 1.8 Focus which is the same engine isnt it?
Today run 13.7 with only 0.38 bar of boost its incredible eaven i cant belive that. In qualifying i run 14.01 two times. But on the first race run 13.7 and then 13.9. I hope to get some video or pictures soon... I also do some dyno but only to 5800 rpm. Today i rise limiter to 7800 for race and car works with no problems at all.
Dyno run for test:
http://www.mobisux.com/album/data/500/20483dyno.JPG
This kit cant be fitet on fiesta because there is no enaught place for belts....
Dyno run for test:
been following this on FiestaTurbo
looking good mate gald amm the machanics are sorted
just one thing ditch teh 3 spokes and get some 5 spoke wheel will look alot better
sound of this fezza is awesome!
Ok i go to 0.55 bar of boost now and new R888 tyres. I have race on sunday on 201m and run belive or not 8.9s. I beat a lot of cars like new 4x4 impreza sti, VR6 supercharger, Honda supercharger, dodge stealth biturbo, fiat tipo 3.0 V6 turbo with alfa engine... Its amazing that engine is still with stock pistons and rods... Its seems like i do proper tuning and im realy hapy.
One movie of race...
http://www.mobisux.com/album/data/50...3MVI_07741.wmv
Throttle body have 75mm diameter, to maping megasquirt takes me 2 hours.
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
like to see it running and proper check your set up
