Urgent - Anyone got a 3 door g/box crossmember?????
Old Aug 8, 2004 | 06:08 PM
SPADGE's Avatar
SPADGE
Default Urgent - Anyone got a 3 door g/box crossmember?????
Sorry for posting this here but i need one of these urgently as mine has been modded for the 4x4 box and i was going to put the engine/box in this week
Old Aug 8, 2004 | 06:11 PM
RichardPON's Avatar
RichardPON
When you do get one mate, can you post a pic of it next to a 2wd one, cos I'm going 2wd into a 4x4 shell too...........
Old Aug 8, 2004 | 06:19 PM
SPADGE's Avatar
SPADGE
Ok mate
The 2wd saff one is obviously ally and offset but the 3 door one is made of pressed steel and the bolts holes are even both sides!
Old Aug 8, 2004 | 06:22 PM
RichardPON's Avatar
RichardPON
Sounds like what I need!
Old Aug 8, 2004 | 07:52 PM
SPADGE's Avatar
SPADGE
Old Aug 8, 2004 | 08:07 PM
Kevin Sharp's Avatar
Kevin Sharp
spadge, if your tunnel has been converted to clear the transfer box the 3 door x member will mount where the bulge in the tunnel is.....you will prob need to make /weld a bracket to the shell...i had to do that when i converted a mk1 xr 4x4 to run 2wd cossie running gear HTH
Old Aug 8, 2004 | 08:09 PM
SPADGE's Avatar
SPADGE
The drivers side channel where the bolts come from is still there at the rearward end Kev and i believe that is where the cross member locates! Maybe on the one you had this was not the case as it had never been 2wd??
Old Aug 8, 2004 | 08:13 PM
Kevin Sharp
mmm cant remember exactly cos its 10 years ago but im sure a 3door x member will want to mount where your "bulge" has appeared
Old Aug 8, 2004 | 08:17 PM
SPADGE's Avatar
SPADGE
Kev here is a pic of a 3 door crossmember if you look at the left hand side where the bolts are for the crossmember you will see the remainder of the channel at the front! This is where my bulge is and not where the bolts are
Old Aug 8, 2004 | 08:35 PM
Kevin Sharp
oh right i just remember having to make a bracket...but on a factory 4x4 floorpan they must give more clearance.....plus its so long ago and i,m getting old
Old Aug 8, 2004 | 08:39 PM
RichardPON's Avatar
RichardPON
This is all I've got (4x4 saff shell)
SPADGE's Avatar
SPADGE
Not going to argue with you there mate
Fortunatly my bulge stops just where that cross member starts so it was either planned that way when it was converted or i am just lucky
Old Aug 8, 2004 | 08:42 PM
SPADGE's Avatar
SPADGE
Rich it looks like you are going to have to do what Kev did on his xr4x4!
RichardPON's Avatar
RichardPON
Don't say that!
Old Aug 8, 2004 | 08:48 PM
SPADGE's Avatar
SPADGE
I can't see any other way around it mate?
I have a 2wd shell out here if you want to come and rob anything from it with a grinder!
I can't even see where the 4x4 one bolted up on yours on the 1 side???
Old Aug 8, 2004 | 08:49 PM
RichardPON's Avatar
RichardPON
SOrry to be nabbing your post here mate.
Mine has some weird welded in group A mount bolt things going on:
Old Aug 8, 2004 | 08:53 PM
SPADGE's Avatar
SPADGE
No prob Rich
Have you a pic from directly underneath where the crossmember should go? as its hard to tell from those pics how they line-up at the moment??
Old Aug 8, 2004 | 08:54 PM
RichardPON's Avatar
RichardPON
Not at the mo mate......
Will get one tomorrow..............
Old Aug 8, 2004 | 08:55 PM
SPADGE's Avatar
SPADGE
Ok mate and i'll climb under this shel and get you a clear shot of what it should look like if it helps!
Old Aug 8, 2004 | 08:57 PM
JC's Avatar
JC
ive got one if it is what you need
thanks jc
Old Aug 8, 2004 | 08:59 PM
SPADGE's Avatar
SPADGE
thanks jc
Ok JC how much and how quick can you get it to me as i need it yesterday
Old Aug 8, 2004 | 09:06 PM
RichardPON's Avatar
RichardPON
I have a fair idea of what a 2wd one should look like, and I think mine looks like a 4x4 should.............just wondering how I combine the two - lol
Other post on the subject ages ago was:
https://passionford.com/forum/viewto...hlight=#894113
Old Aug 8, 2004 | 09:11 PM
SPADGE's Avatar
SPADGE
Rich
Just looking at the pics in that other thread and from what i can see in pic 4 showing a 2wd ally crossmember it looks like a 3 door one will sort you out
Old Aug 8, 2004 | 09:18 PM
JC's Avatar
JC
name your price and ill get it out to you for tues morn
thanksjc
RichardPON's Avatar
RichardPON
I hope so too..............
Right - one MORE 3 door gearbox x-member needed
Old Aug 8, 2004 | 09:28 PM
SPADGE's Avatar
SPADGE
thanksjc
John you have a PM mate
Old Aug 10, 2004 | 08:05 PM
SPADGE's Avatar
SPADGE
thanksjc
John did you send it mate as i havn't had it
chowfornow
14
Jan 5, 2019 09:01 PM
155lee
Sep 6, 2016 11:10 AM
mpilk
Sep 27, 2015 09:21 AM
Vacuman
Sep 22, 2015 12:09 PM
