how do i tell if its a 4x4 head
how do i tell if my head is a 4x4 1 was told the turbo oil feed would come from the head if it was a 4x4??is this write,its on the 205 block in my 3dr thanx
4x4 head has no lug on exhaust side for turbo damper and water temp gauge sender is with engine temp sensor at the back on the inlet side instead of next to thermostat... compared to 2wd!
If your running a 4x4 head and 205 block hope you have 4x4 pistons otherwise your cr ratio would be high
200 block and pistons and 2wd head = lower than standard comp ratio
Just a thought?
Just a thought?
