Caliper maintenance
Old May 23, 2006 | 01:12 PM
C14KEE's Avatar
C14KEE
Default Caliper maintenance
got a feeling one of my calipers might be giving me a bit of stickon every now and again
whats the quickest and easiest way to give them a bit of lube to free them up??? WD40 at the piston??
Sorry im a beginner
Old May 23, 2006 | 04:45 PM
Moonie's Avatar
Moonie
You dont really want to be spraying wd40 around your brakes.
If the caliper piston is sticking then there are service kits available which inllude all the necessary seals to enable you to strip down, clean and rebuild the caliper. However, it may be the caliper sider pins that are sticking or even just the pads sticking in the caliper.
If the caliper piston is sticking then i personally wouldnt go to the trouble of rebuilding/servicing it. Reconditioned calipers are not that expensive.
Old May 23, 2006 | 04:47 PM
C14KEE's Avatar
C14KEE
cheers for the advice fella
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
cossirob
Sep 3, 2015 09:17 PM
