Breaking ESC COS- LAST FEW BITS - OFFERS TO CLEAR- 11/08/06
Right, complete car has gone, these are all the bits left. If you're interested, then PM me or email on dave.mulheran@btinternet.com
NO SENSIBLE OFFER REFUSED
Aeroquipped block to breather hose , -10 with swivel aeroquip fittings and block to aeroquip fitting adaptor
2 x Optima dry cell batteries (one black top, one yellow top)
4 x X038 injectors (untested/used)
Complete dash and arm rest console (mint) Centre console SOLD
Boot carpet and Parcel shelf (mint)
Rear diff, rear shafts, rear ARB, rear beam
Front ARB powdercoated and fully polybushed (Mint)
Powdercoated TCA's (mint)
Underside exh heat shield (great condition)
Front propshaft
Main propshaft
Front Diff
1 x Graham Goode 4x4 steering rack as NEW
1 x used steering rack in perfect working order
a bundle of silicone water hoses, most red, some black
a pair of powdercoated window wipers in eggshell black and new bosch blades - mintos
DSM032 £350 PAIR OF GENUINE ESC COS WINGS FRONT WINGS IN GREAT CONDITION> NO DINGS OR DENTS. IGNORE THE DUST IN PICTURE. PROFFESIONALLY REMOVED. NO DAMAGE. HARD TO FIND NOW
DSM035 £100 OPTIMA YELLOW TOP 4.2 12V 55AH CAR BATTERY - THE BEST BATTERIES AVAILABLE. ONE OF TWO FOR SALE. DUAL PURPOSE STARTING AND DEEP CYCLE. LASTS 2 TIMES LONGER THAN OTHER BATTERIES rrp £180. Dual Purpose starting and deep cycling.
Lasts up to 2 times longer than other batteries.
Constant performance quality keeping your battery running at the same level even as it's being discharged.
More power in the initial 1, 3, 5, and 10 seconds of the starting process than comparably rated conventional lead acid batteries.
Ideal for seasonal use, fully charged, it can sit unused for up to 12 months at room temperature (or below) and still start a car.
15 times more resistant to vibration than other batteries.
Nonspillable and can mount in almost any position .. WILL NEED CHARGING, LEFT SITTING FOR A WHILE
DSM036 £100 OPTIMA YELLOW TOP 4.2 12V 55AH CAR BATTERY - THE BEST BATTERIES AVAILABLE. TWO OF TWO FOR SALE. SAME SPEC AS ABOVE BUT WITH COATED BLACK TOP. WILL NEED CHARGING, LEFT SITTING FOR A WHILE
EXHAUST UNDER CAR HEAT SHIELD - RARE
Front propshaft
Main propshaft
Front Diff
Originally Posted by capri-rs
oilcooler and remote filter/takeoff plate??
2 options
Oil system with laminova cooler
Oil system without
cheers
add this to my list i will send cheque to morrow, can you send this with the fans to keep the price down cheers andy
Bargain
have you got any mag bilsteins for sale
