2wd parts + escos front wings *more added*
Old May 22, 2006 | 10:10 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Default 2wd parts + escos front wings *more added*
2wd complete head, cams included. measures 138.4mm. area around waterways are excellent but there are det marks in the chambers. being crack tested at the moment and will get pics up as soon as its back
looking for £300
2wd rear diff fully working. has the very slightest of whines when cruising but nothing major at all. has been on my car for 6 months and is no worse than when it first went on will probably remove it from the car this weekend.
looking for £200
2wd rods and pistons (i think) pistons part no yb0432 mahle's. there are some scrapes up the sides of the pistons and signs of det on a couple. they might do to get you out of trouble. rods look ok
looking for £100 the set
1 set of escort cosworth front wings (still fitted at the moment, but will be drilled off within the next week) mint condition, no dents/chips/rust etc.
looking for £300 the pair
Old May 26, 2006 | 06:14 PM
Turbo Zetec
Engine Machinist
up
Old May 29, 2006 | 08:10 PM
Turbo Zetec
Engine Machinist
pics for some of the above.
Old May 29, 2006 | 08:19 PM
Turbo Zetec
Engine Machinist
a few more bits:
sapphire cos bootlid with spoiler, slightly tatty £30
cossie twin fans £20
2wd dash, okay apart from broken glove box lid, inclides dials £40
2wd cambelt cover £10
2x standard airboxes (one has a pipe broken off, easy fix) £5 each
3i Jim
Nov 20, 2015 05:12 AM
james kiely
Aug 28, 2015 08:58 PM
C2 MAK
Aug 20, 2015 09:46 PM
john_3.0s
Aug 15, 2015 07:44 AM
paceo
12
Aug 4, 2015 08:50 PM
