Cossie Help for my mate (SVONY)
Hey guys any of you cossie gurus give my friend a hand? he's new to cossie, and just picked one up and is doing a minor car rebuild. Thanks peeps!
He had a topic in Technical but had no replies
HELP!!!! Spark/Fuel will not start...Cossie 4X4
Originally Posted by svony
As the subject says, I have spark at the coil/spark plug, fuel pump primes when the key turns on and fuel at the rail (after a few minutes of cranking the plugs are wet), I also replaced the filter, checked the relays and fuses near the ECU... no luck. Could this be a bad crank sensor?
Before this the car would start but the idle would hunt, this is my first Cossie and I have no idea what else to look for.
Russ Payne
Sep 25, 2015 08:29 PM
