just died help please
Last night on way for a meal with the missus crusing at 30 in 4th engine just died and will not start cant hear the fuel pump when you turn the key
has anyone had that happen and could someone point me in the right direction of where to look first would have thought a realy would have gone on start up any help i would be very greatful.
CheeRS Martin
has anyone had that happen and could someone point me in the right direction of where to look first would have thought a realy would have gone on start up any help i would be very greatful. CheeRS Martin
yes all the dash lights come on and it turns over fine.
which realy is it ? and where is the fuse couldnt see one in the fuse box for the pump cheers will check the Knock switch aswell
Let me know how you get on
Relay and fuse for pump are behind the glovebox on passenger side
Pull glove box out,fuel pump relay is a yellow one,with a yellow multiplug going on to it
As above check your fuel cut switch in the spare wheel well,quite often under a couple of inches of water
Thanks allot for your help will check them out tonight will let you know what i find
martin
martin
Good thing about this site,allways some1 willing to offer advice/help out
lol mine used to do about once every 2 mnths.....a quick smack on the dash and she'd fire up again
Traced it to a dodgy connection on the ecu plug...cleaned it up and she aint done it for a few yrs now
Im wondering how you manged to come round to "smack the dash", oh thats right its cossies weve got here, sometimes they lead you to that frustration, i usually use my head as the hitting tool, while shouting "why meeee"
Classic
, gotta love the Cossies aint ya
i dont know if the cossie pump is the same but i have a 2.0dohc saph and the fuel pump, which is accessible through the spare wheel, has a reset button on it for some bloody stupid reason. mine has tripped twice and the first time it happened i was stumped for days. pissed me right off, bareing wires back, checking plug connections an shit. push the little button o the pump and its sorted.
Hi all sorry bout the delay gettin back to you moved house an had no internet
but turned out it was the fuse to the ecu relay but whilst i was checking all the sensors to the ecu i found that the phase sensor is wired to pins 6 and 22 not 5 and 23 as the drawings all point to anyone found this before as it runs fine any info would be great cheers lads
just found out it was the knock sensor and the phase sensor that were pluged in to the wrong ones swaped them back and all is well
Big thanks 2 the boys at motorsport developments for the info
