P8 ECU UPDATED sterio MD player KONI with a hub +MORE !!
P8 ECU IN L1 CASE FOR THE RS500
WORKING FINE STANDARD
£350 inc p+p
can fit into p8 case at but would prefer to leave in l1 case checked by ahmed !!
OR WITH NEW BABY BOARD AND CHIP TO RUN GREENS £450 or £145 board and chip NEW
BOARD ALONE COST £350
KONI 2WD FRONT WITH SRPRINGS AND REAR DO HAVE SOME SPRING IF NEEDED £100 INC P+P
auto meter air mixture without lamba with box and paper work
with boost +/1 30psi no bulb white face orange needle was held in by double sided tape cant find the bracket
the pair
£50 £59 with p+p
water temp and oil pressure
need temp adaptor fitted and brackets
with matching boost -15 to +30 psi
white face black needle
£40 £45inc p+p
3 door twin pod for a post £20 inc p+p
full saff interior with everything dash pastics shelf £150
moonstone standard bonet £30
also standard 4x4 shocks £50 or offers replaced for konis
CAR REG OFF MY RS500
E700BEV IF YOU WANT ITS ON A RETANER AND WILL EXEPT GOOD OFFERS
ALSO
FORD ECU OUT OF A 2L SIERRA TWIN CAM OFFER
Sony mini disc head unit MDX-C8970R
CAN CONTROL MP3 AUOTOCHANGER BUT NOT INCLUDED
FULLY WORKING AND TAKEN OUT DUE TO DVD HEAD UNIT
LOOK LIKE NEW AND LITTLE USE AS I DIDNT HAVE THE CAR RUNNING FOR LONG WITH IT IN !!
£100 inc p+p cost £430
£350 inc p+p
the pair
£50 £59 with p+p
£40 £45inc p+p
ALSO
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
