Hi spec 300mm rear brake fitting instructions wanted
Old May 21, 2006 | 04:34 PM
MATCOS's Avatar
MATCOS
Default Hi spec 300mm rear brake fitting instructions wanted
Can someone send me a copy or scan a copy of the instructions to fit the rear 300mm Hi spec brakes please.
would be very much appreciated
Old May 22, 2006 | 12:15 PM
MONSTER's Avatar
MONSTER
Are they the same as the compbrake jobbies?
Old May 23, 2006 | 12:12 PM
MATCOS's Avatar
MATCOS
I think they are all slightly different-I am fairly confident they are right however need to know 100% before MOT
Old May 23, 2006 | 03:34 PM
MONSTER's Avatar
MONSTER
What do you need to know?
Old May 23, 2006 | 05:12 PM
MATCOS's Avatar
MATCOS
Well I have fitted them and they work, but I dont know if they are exactly right?-they do only seem to be able to be fitted one way but I need to know for sure. I have seen your pics previously and mine are positioned the same but like you say yours aren't Hi Spec? - is there more than one way to fit them?
Cheers Monster
Old May 23, 2006 | 05:44 PM
THE RADMAN's Avatar
THE RADMAN
ill take some pics of mine when i remove the wheels in the next few days hopefully
Old May 23, 2006 | 05:55 PM
MATCOS's Avatar
MATCOS
Nick are yours Hi Spec
Old May 23, 2006 | 08:05 PM
MONSTER's Avatar
MONSTER
with the kit I bought there was only 1 obvious way to fit them, as long as they work i cant see a problem with the MOT..
Old May 23, 2006 | 08:11 PM
MATCOS's Avatar
MATCOS
Maybe I am being paranoid -I am just imagining them being torn off when I give it some serious braking action and the car ending up on its roof in a field
Old May 23, 2006 | 08:57 PM
THE RADMAN's Avatar
THE RADMAN
the caliper brackets are
Old May 24, 2006 | 05:41 PM
MATCOS's Avatar
MATCOS
Cheers Nick-I will wait for your photo's
track.focus'd
Aug 12, 2015 05:53 PM
Aug 10, 2015 12:08 PM
Bosch
Aug 4, 2015 05:14 PM
adriansaleem
Aug 3, 2015 11:21 AM
