advanced escort RST question...how knows the anwser ??!!
Old Aug 7, 2004 | 06:38 PM
joo5t's Avatar
joo5t
Default advanced escort RST question...how knows the anwser ??!!
I have got this weird problem...
when my car is running idle and I start to hit the brake a couple of times in a row, my engine doesnt run smooth anymore until I stop hitting the brake paddle.
what can be the problem ?
Old Aug 7, 2004 | 06:41 PM
DazC's Avatar
DazC
There isn't a problem unless it runs seriously un even. Does the idle settle down if you press the pedal and hold it down?
Basically your brakes are servo assisted and it gets it's vacuum supply from the inlet manifold...when you press the pedal, it introduces a small amount of unmetered air into the manifold as the engine has to replace the vacuum back in the servo which causes a slight uneven idle breifly...
Old Aug 7, 2004 | 06:49 PM
st3v3's Avatar
st3v3
as DazC said matey
Old Aug 7, 2004 | 07:07 PM
joo5t's Avatar
joo5t
hm ok, but it seems pretty weird.
thanks
Vincereese
Jun 1, 2023 09:14 AM
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
dlwarrior
Aug 5, 2015 10:19 AM
