RST gearbox/linkage question
Old May 20, 2006 | 09:00 AM
Chavtastic's Avatar
Chavtastic
Default RST gearbox/linkage question
Hiya all.
How does the gear linkage come off the gearbox on an RST? I see the 13mm nuts and have undone them, but it doesn't seem to come off the box itself. I've also unclipped the cable.
Also, are the boxes the same on any other CVH Escort of the same age?
Old May 20, 2006 | 09:10 AM
JesseT's Avatar
JesseT
You loosen the 13mm nut on the clamp and just pull the linkage off.
The gearboxes are very similar, differences are the LSD equipped differential, crownwheel teeth size and the gear ratios.
Old May 20, 2006 | 05:31 PM
Chavtastic's Avatar
Chavtastic
Okay cheers I'll give it a go!
Hopefully there will be a market for chromed linkages (which I presume are the same across the range?)
Old May 20, 2006 | 07:49 PM
SafeChav's Avatar
SafeChav
Once its slack u will need to push the selector shaft in to have the clearance, but it just slides off as said
Linkages AREN'T the same, a few different ones. (4 speed, 5 speed, MK3, MK4)
Old May 20, 2006 | 11:20 PM
SafeChav's Avatar
SafeChav
Ive just noticed your name
Chavtastic
New Chav on the block
Old May 22, 2006 | 10:09 AM
Chavtastic's Avatar
Chavtastic
Don't worry I'm no chav...
Old May 22, 2006 | 10:57 AM
SafeChav's Avatar
SafeChav
Makes two of us then
A.t.p
Oct 23, 2015 07:54 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
A.t.p
Sep 29, 2015 05:04 PM
