From Std Actuator to a -31 Actuator
what changes need to be made here?
as im currently on a std actuator that i suspect has dies as i have no boost,
im running a chipped ecu with bleed valve, i take it due to the different opening pressures i need to reduce the amount the valve is bleeding out?
cheers for any response/help
either change it yourself and adjust it for hardly any boost or just nurse it to where ever you get it set up (its not that hard to drive off boost!)
Interpro are roughly £150 for a full set up,but they are very good!! Dave is excellent with RS Turbo's
put the bleed valve in the bin....
adjust the new actuator nut so the car boosts f all and then go get it set up, dont just bung it on and drive off, a friend of mine did it and was boosting 24psi on a std engine....... lucky he was clever enuff to come back and adjust it
Cossie92
Sep 21, 2015 01:38 PM
