Fuse Box Seal
Old May 18, 2006 | 06:53 AM
Sheldy's Avatar
Sheldy
Default Fuse Box Seal
After welding a replacment panel under the fuse box I now need the large rubber o-ring which goes under the fuse box and stops water entering under the dash.
However I 've now found out its no longer available from Ford!
Any idea where i can get one?
Apart from the scrapyard!
Old May 18, 2006 | 08:35 AM
Zetecfiesta's Avatar
Zetecfiesta
i didnt know they had one! which might explain why mine leaks!
do you have the finnis code for it, might be easier to find it!?
Old May 18, 2006 | 12:34 PM
SafeChav's Avatar
SafeChav
I can find you a finis code later.
If not sealant, or a second hand one
Old May 18, 2006 | 02:21 PM
Sheldy's Avatar
Sheldy
I have the finis code in the car if anyone knows anywhere that might deal in obselete ford stock?
Didnt really want to go the second hand route even though my cousin owns a scrap yard! But if needs must i'll have to!
Old May 18, 2006 | 04:01 PM
LEE-RS's Avatar
LEE-RS
Custom
try http://www.fordpartsuk.com/ they deal in obselete ford stock
Old May 18, 2006 | 11:16 PM
Zetecfiesta
still need the finis code though!
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
Russ Payne
Sep 25, 2015 08:29 PM
