cosworth stereo
has anyone ever put a standard escort cosworth stereo into a 3door? trying to find where abouts to get a connector block for the wiring, dont want to be cutting the standard wires
any help would be great cheers
is it the one with the cd player?
you can get a split power loom from out of the back of most granada's of that vintage (as long as they haven't been cut by the goons in the scrapyard)
if you want to mount the amp too you may need to use the wire from a sierra as the granada ones are about 2 inchs too short
the second problem you are going to find is getting the cd player into the lower slot
it's not the same size as the top one but you can get a bit of plastic to make it up properly
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Adam Graham
Sep 6, 2015 06:04 AM
