Strange Tapping?
There seems to be a tapping noise and feeling coming from the fuel filter and along the fuel line to the rail, but not the rail its self. :-?
It also increase's in speed with revs, anyone any idea?
Just to note this is from a frst with a fresh rebuild.
Originally Posted by Shannon
Originally Posted by Moonie
Has Maroo left a spanner somewhere?
and he's me thinking you'd post something of some use
Seriously, im not rite up on the fezzi turbo fuel systems but most EFI systems have some sort of pulsation damper in the fuel line to smooth out the pulses in the fuel caused by the injectors opening and closing, you havent removed or changed anything like that have you?
Have you moved the fuel line in any way, is it catching on something and transmitting vibration?
Have you altered the fuel pressure or changed the regulator, pump, injectors or anything on the fuel system?
Bit of a difficult one without actully hearing the noise to be honest.
The fuel system is exactly the same as it was before the rebuild. Nothings been changed and nothings catching
Originally Posted by sexy xr2i
try to pm brooksey hes a mechanic and gives good advice hun x
You two timing beeeeehatch
What about me
Shannon: FRST's have a damper inside the fuel tank on the sender directly after the pump. If its pulsation that is the problem then its more than likely going to be this
What about me
and me
What about me
and me
the throttle damper is on top of the pump in the tank.
Stay out of it you i saw her first
I explained it much better
Presumably off the chain means like, off the box sort of thing???
Or does it mean shes going to be letting me off the chain lol
Believe it or not i rarely drink!!
i dont drink much tbh mate, maybe go out on piss once a month if that, not that i dont want to the night clubs over here are fucking dogshit! and way to small.
Anyway.......about the tapping????
(sorry)
(sorry)
Pack of cunts, find your own thread to flirt in
Still tapping away with a new filter.
mate i would edit the c word out, theres a rule against it now so dont piss them off.did you try the throttle damper in the end?
I havent tried the damper, I need to see if I can get hold of a new one in the morn.
