4x4 cossie rad fan on too much ...
Old May 15, 2006 | 08:59 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default 4x4 cossie rad fan on too much ...
Well, I think it is...
It was running when we got off the motorway yesterday, air temp wasn't that high, engine temp was fine, and we'd been driving along just fine, I don't understand why the fan would run as we come off the m-way to a roundabout
Could it be the temp sensor, I thought they usually stopped working altogether, not working overtime and being zealous...
Or, something more serious like h/g on it's way But then again, no oil I can see in the water / mayo in the oil / or high engine temps or anything....
Oh, and the fans cut out shortly afterwards, so the cooling is working
Any ideas ???
Thanks
Old May 15, 2006 | 09:06 PM
SafeChav's Avatar
SafeChav
Usually when thermostats start sticking open the fans come on very frequently and for very short amounts of time, although if u had just come off the motorway and the stat was open too much i wouldn't of expected the fan to be on.
Could well be the fan switch, they're only bi-metallic strips after all.
What does it do when its left idling? does it cut in way early?
Old May 16, 2006 | 01:12 PM
frog's Avatar
frog
Difficult to tell, the temp gauge in the car isn't that accurate... But the fans do cut in.
I am just surprised that they would be running after a long blast on the motorway (and not caning it either which could explain it).
Old May 16, 2006 | 01:15 PM
SafeChav's Avatar
SafeChav
Well, first things first you need to sort the gauge in the car out.
Dont forget when you are on the motorway theres a lot of air flow then to suddenly slow down sometimes the temperature does rise for a short amount of time.......
Old May 16, 2006 | 01:21 PM
frog's Avatar
frog
It's the std gauge, it works fine, but there's only a tiny amount of movement in it between normal operating temp, and fans cutting in if you see what I mean
Old May 16, 2006 | 01:34 PM
SafeChav's Avatar
SafeChav
I could be wrong but standard gauges aren't usually that precise?? You sure the gauge/sender aren't playing up?
Old May 16, 2006 | 01:42 PM
frog's Avatar
frog
The gauge and sender appear to work ok, I mean the gauge is low to start with, then rises after a few minutes of driving as it always has in the last 8 years I've owned the car
Normal operating temp is as usual. Unless the sender stops working after a given temperature, all appears ok on that front.
Old May 16, 2006 | 01:45 PM
SafeChav's Avatar
SafeChav
I've had a gauge before that would rise to the bottom of the normal temperature on the guage, when the engine was at 50-75% of operating temp, and would then go back down to nothing before the fan cut in.......
Might be worth a quick once over
Old May 16, 2006 | 01:57 PM
frog's Avatar
frog
How can I go about checking water temps without making holes in my hoses and fitting aftermarket gauges to the car ?
I suppose I could take a reading off the water temp sender while I am driving, and off the ECU too
Old May 16, 2006 | 01:59 PM
SafeChav's Avatar
SafeChav
You can check the gauge by pulling the sender wire off and bridging it to earth, which should show as max. temperature.
And if thats ok, u could try a new sender for the couple of quid they are worth?
The ECU CTS would have different values to the one for the gauge im pretty sure.
Old May 16, 2006 | 02:13 PM
rsnissan's Avatar
rsnissan
Greg if i were you i would deal with the root of the problem.................
take the fan switch out of the radiator and place in a pan of boiling water with a thermostat and check the resistance with a MM to see when it tirggers the fans then go from there.
Old May 16, 2006 | 02:19 PM
frog's Avatar
frog
Good plan sir
Old May 16, 2006 | 02:22 PM
SafeChav's Avatar
SafeChav
Good plan sir
Agreed
Old May 16, 2006 | 02:25 PM
rsnissan's Avatar
rsnissan
Obviously I meant thermometer and not thermostat in the pan
Old May 16, 2006 | 02:31 PM
SafeChav's Avatar
SafeChav
I have to admit i was a at the thermostat bit
Let you off this once, dont let it happen again
simonmcf
Sep 22, 2015 08:40 AM
truffleshuffle
Sep 10, 2015 09:35 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
Ben26
Sep 3, 2015 07:55 PM
