Icv???
Old May 15, 2006 | 08:09 PM
jamiechadburn's Avatar
jamiechadburn
Default Icv???
sorry lads just want to check somthing having bad idel probs when warm reving at 2500-4000 revs tryed disconecting plug but dose not do anything just carries on playing up!! so i got anouther as old one looked shaged!! Its the red top engine and the capp was grey and the new one is a red cap is this right??
thanks jamie
Old May 15, 2006 | 09:22 PM
THE RADMAN's Avatar
THE RADMAN
dont think it matters mate,seen a few with a red cap about lately
Old May 15, 2006 | 09:33 PM
CosKev3's Avatar
CosKev3
Would think if you've disconnected the plug from the ISCV and its made no difference its not that at fault
Sounds like throttle cable sticking or throttle butterfly sticking in throttle body for revs to be that high
Or base idle screw dropped out of throttle body is a possibility
Old May 16, 2006 | 02:24 AM
boost mad's Avatar
boost mad
what enigne
Old May 16, 2006 | 07:40 PM
jamiechadburn
thanks lads Ill check the throttle body
**caz**
16
Jun 25, 2010 08:22 PM
Karlos G
Jun 18, 2009 02:22 PM
RS500/364
Nov 20, 2007 05:23 PM
kennert
Apr 10, 2006 03:46 PM
