Re-gassing Air con
Old Aug 6, 2004 | 03:36 PM
Rhys's Avatar
Rhys
Default Re-gassing Air con
On my 306 the Air con cools the car down but doesnt make it cold! Does this mean the the Aircon might need re gassing? If so how much does it normally cost to do this?
Old Aug 6, 2004 | 03:37 PM
Physio's Avatar
Physio
I think it's about £90 mate, i stand to be corrected.
Old Aug 6, 2004 | 04:18 PM
Nath's Avatar
Nath
Theres someone that comes on here that does it pretty cheap. Are you sure the pump and/or the fuses are ok?
By the way we'll be in your neck of the woods tonight Rhys
Old Aug 6, 2004 | 04:29 PM
Rhys's Avatar
Rhys
90 that much for a bit of gas?
Cool, Nath give me a Ring when you come over dude!!
Nah the pump is working fine etc as its cool air coming through but it just doesnt make you think its getting cold now etc! lol
Old Aug 6, 2004 | 04:30 PM
CabrioTurbo's Avatar
CabrioTurbo
yep its '£90' from the ford garage near me.. but i got my mate to do my mums for free! make a propper big difference!
Old Aug 6, 2004 | 05:33 PM
markk's Avatar
markk
£ 90 is about right tbh , for that you should get a full drain down , vac out , pressure test , fresh oil , and a leak dye fitted
Old Aug 6, 2004 | 05:35 PM
MATCOS's Avatar
MATCOS
Slightly off topic,sorry, but I got told that they cant regas cars pre 93 as they have older style gas that is now illegal to use,is this true? also does anyone know how you tell if the air con is leaking?
Old Aug 6, 2004 | 06:00 PM
CabrioTurbo
it isnt cool when you turn it on
If you want to doubble check then you have to use the leak dye stuff.
Old Aug 6, 2004 | 06:03 PM
markk's Avatar
markk
theres a few ways for leak detrection for diff refrigerants , ie, ultraviolet , and ultrasonic
Old Aug 6, 2004 | 07:35 PM
Rob M666SCC's Avatar
Rob M666SCC
We charge £70 all in,
Old Aug 6, 2004 | 07:37 PM
Uncle Henry's Avatar
Uncle Henry
ring around mate, a mate of mine does it mobile for £55-£65, inc re-oil/pressure test etc!
Old Aug 6, 2004 | 08:12 PM
Jamz's Avatar
Jamz
If it's currently using the new gas it'll need to be converted to use the new stuff.
Old Aug 6, 2004 | 09:26 PM
MikeyXR2i's Avatar
MikeyXR2i
Might be a sensor going dicky, i had my rover done i got charged 80 quid, week later it went warm and stopped working, so had it checked again, the Gas was still in it, so i was told a sensor somewhere on the system has gone down, aint checked yet though.
Old Aug 7, 2004 | 01:40 AM
markk's Avatar
markk
hmmmmm tyheres alot of people who think they know about aircon who actually dont only trust reputable garage like scc who actually kno wha there on about , and yes ive actually spoke to rob so
Old Aug 7, 2004 | 08:10 AM
Rob M666SCC
Old Aug 7, 2004 | 10:02 AM
alan rainbow's Avatar
alan rainbow
the gas you are talking about is r12 and is now illegal to re gas with r12 good job ive got a bottle knocking about for pre 93 cars you can get a drop in gas which is r49 or you can have them retro fitted to use 134a which the new cars use most cars tend to loose a bit of gas when a/c not used for a while due to seals in the compressor drying out of oil rhys you ac sounds like its a bit sort of gas you can pressure test the system to see if it has any leaks common leaks are on the condenser or joints to the condenser a die can be put in the system and a ultra vilot light used to detect leak but then again what do i know iam only a airconditioning engineer
GUZZLER's Avatar
GUZZLER
i had this prob with my '92 saff, but,
aparently there is an oil which mixes ok with the old oil & new gas,
with out the blatant need to change anything else, my car is being done next week, i shall know for deffo then
Old Aug 7, 2004 | 10:04 AM
GUZZLER's Avatar
GUZZLER
good stuff alan, put it a bit better than me
Old Aug 7, 2004 | 07:55 PM
Rhys's Avatar
Rhys
Cool my car has done about 69k now and hasnt had a re gas so prob needs one by now!!!!! Will see if i can find someone who will do it at a resonable rate now!
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
