Escort Cos - Got a T4 or GT30/35, but want to keep...
...your OE airbox for noise reduction, then here is the cure
Obviously the standard airbox is only 65mm intake, which is too small for the 76mm hose required for the T4. However, the entry into the Escort airbox is actually 87mm, but features a glued in plastic reducer.
This can be cut off and removed, leaving the full 87mm entry hole.
We then do a billet alloy machined intake adapter that pushes in to this and sleeves down to the correct 76mm for the T4.
This does actually push in fully, but it is a bitch to get out, so I didn’t push it fully home
We also do one that allows the fitting of a GT30 / GT35 (100mm) hose to the standard airbox – obviously the entry is reduced to 85mm where it goes into airbox, but it allows the fitting of a proper 100mm hose whilst retaining the OE look and sound reduction
Combined with this, is a complete cure for all your T4 on an Escort Cosworth issues
https://passionford.com/forum/viewto...182248&start=0
All parts in stock, and the airbox mod can be carried out for you on an exchange basis
£25 + delivery (supply only of adapter)
£40 + delivery (supply of airbox lid pre-fitted with adapter - exchange basis).
.We also do one that allows the fitting of a GT30 / GT35 (100mm) hose to the standard airbox – obviously the entry is reduced to 85mm where it goes into airbox, but it allows the fitting of a proper 100mm hose whilst retaining the OE look and sound reduction
that first pic!
the insulation tape around there.
i did that on my air filter pipe and it sucked it off the alloy trumpet and fooked my turbo up.
so please don't have any tape near the induction side, buy one of them off Mike.
that first pic!
bejesus!!! FUBAR !!!
AVA just made something like this for Jam's(Escorton8's) escort..
your about a week late mike
Jam
Shame that beautifully made roose hoses for fitting of the recir to complement this DOESNT COME IN F***ING 100mm OUTLETS!!
You should of specified this being the salesman that you are!!
Originally Posted by Yeti Racing
Well I take it as you are in the running for 'businessman of the year' you'll be looking into remedying this for us GT owners!
Just did this to mine Jase:-
Crap pic but you get the jist of it I think!! Mind you I have the DV spout welded on my intercooler just under the main outlet (TB side) so you can only just see the bit of pipe going back into the airbox lid. Much neater in my opinion.
The hose itself has all been trimmed up now as well
Does the ducting to the standard Escort Cosworth Airbox still work when you install an RS500 spec Intercooler lads?.
I ask this as I'm about to buy an Escort Cosworth and I had the problem with my Sapphire (when I installed the RS500 spec Intercooler on my Sapphire I had to remove the factory ducting that ran from my grill into the airbox so all I was left with was an airbox with a square hole in in right next to the turbo ).
Hence the only reason I put a K&N pod filter on my Sapphire.
By the looks of things and the pics you guys have posted it's much better to keep the factory airbox than go to a pod filter right?
Yes it does mate, Mine ran a Radtec 500 IC and standard airbox!
And its used to prevent heatsoak from the engine bay!
Do me a favour please and send me some internet links of turbo suppliers in NZ preferably Auckland area, I'm getting my agent over there to send me some bits!
Yeti Racing
no dump valve on yours? i thought on the gt series turbo's you had to run one.
because they are fragile compared to the normal t series?even a recirculating one.
i await my
i await my
Yeah baby looking back you are right! I'll take one of these
for myself then!
I'm deffo running a dumpvalve mate, just not the wooshing kind!
for myself then!
but other than that the car is the bollox.i see why people rate them so highly,just doesnt have the character of a cossie
You heathen!
I Lurvve the look of evo6!
have to say i would have it over a skyine or rx7 or scooby.
totally awesome car.only 310bhp but handles so well
lot of money spent.but only on the right stuff
