Escort Cos - Got a T4 or GT30/35, but want to keep...
Old May 15, 2006 | 09:39 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Default Escort Cos - Got a T4 or GT30/35, but want to keep...
...your OE airbox for noise reduction, then here is the cure .
Obviously the standard airbox is only 65mm intake, which is too small for the 76mm hose required for the T4. However, the entry into the Escort airbox is actually 87mm, but features a glued in plastic reducer.
This can be cut off and removed, leaving the full 87mm entry hole.
We then do a billet alloy machined intake adapter that pushes in to this and sleeves down to the correct 76mm for the T4.
This does actually push in fully, but it is a bitch to get out, so I didn’t push it fully home .
We also do one that allows the fitting of a GT30 / GT35 (100mm) hose to the standard airbox – obviously the entry is reduced to 85mm where it goes into airbox, but it allows the fitting of a proper 100mm hose whilst retaining the OE look and sound reduction .
Old May 15, 2006 | 09:44 AM
GARETH T's Avatar
GARETH T
looks job done too me
Old May 15, 2006 | 09:49 AM
Porkie's Avatar
Porkie
Old May 15, 2006 | 09:51 AM
Mike Rainbird
Caraholic
Combined with this, is a complete cure for all your T4 on an Escort Cosworth issues
https://passionford.com/forum/viewto...182248&start=0
All parts in stock, and the airbox mod can be carried out for you on an exchange basis .
£25 + delivery (supply only of adapter)
£40 + delivery (supply of airbox lid pre-fitted with adapter - exchange basis).
Dr. Ickxs
Sep 15, 2015 10:15 PM
gcfcos
88
Sep 15, 2015 03:48 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
