zetec turbo oil filter in series 2 help.....................
Old May 14, 2006 | 11:19 PM
stevenebm's Avatar
stevenebm
post whore
Default zetec turbo oil filter in series 2 help.....................
awrite folks.just went to put oil filter on the zetec turbo in ma s2 and it wont fit.its hitting against the body at the drivers side.filter would need to be half the size to fit.what will a do or what do people with same engines do.cheers
Old May 14, 2006 | 11:21 PM
david's Avatar
david
Have you put the S2 water cooling jacket on the zetec block ?
Old May 14, 2006 | 11:35 PM
stevenebm's Avatar
stevenebm
post whore
why would that affect the oil filter hitting the body mate?
Old May 14, 2006 | 11:36 PM
Red16's Avatar
Red16
dont think that would make any difference david the oil filter fits on the end of the oil pumo on a zetec bottom end.
stevenebm ive heard of peope using a renault clio 16v or r5 gt turbo oil filter, theyre a lot smaller than the zetec units.
let us know how you get on
Old May 14, 2006 | 11:38 PM
david's Avatar
david
The water cooler will make the filter sit further out and could cause the filter to foul.
I had my 1.8zvh in the black car using a standard zetec filter with no problems.
Old May 14, 2006 | 11:40 PM
david's Avatar
david
Was talking pish there
Think you must have a mondeo oilpump and need to swap it to an escort/fiesta pump.
Old May 14, 2006 | 11:41 PM
david's Avatar
david
http://www.quantums.info/zvh.htm
Have a look in there mate.
Old May 14, 2006 | 11:44 PM
stevenebm's Avatar
stevenebm
post whore
cheers mate a will let you know.will ask some folk on here with zetec turbos and see what they have used
Old May 14, 2006 | 11:45 PM
Red16's Avatar
Red16
seen Jim Hearne's site before, its a brilliant read
Old May 15, 2006 | 12:04 AM
XRT_si's Avatar
XRT_si
Renault 5/Clio ones are half the size and apparently fit making them perfect for the Zetec Turbos so ive heard.
Old May 15, 2006 | 12:06 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i used a escort zetec pump and normal zetec filter and had no probs at all
Old May 15, 2006 | 12:30 AM
luke89's Avatar
luke89
Team HOTHOT!
aparently cvh filters also fit on zetecs and are proper small compered got one here but cba to fit it as my zetec one fits in my fez
Old May 15, 2006 | 10:17 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
a cvh one is half the length of a zetec one
Old May 15, 2006 | 10:35 AM
Sketch's Avatar
Sketch
I use a standard RS Turbo oil filter
Old May 15, 2006 | 12:28 PM
ballin's Avatar
ballin
ditto, efl500 iirc or something like that!! or maybe efl300
Old May 15, 2006 | 01:18 PM
Adam Ash's Avatar
Adam Ash
Im going to fit one of these
to my 2.1zvh in my xr2
from a renault 5 turbo and is approx 1/3 of the size of a zetec one
Billy_RS
16
Oct 11, 2025 09:41 PM
Oct 9, 2015 07:38 PM
Dubs44
Aug 21, 2015 02:42 PM
mrmann
Aug 20, 2015 11:24 PM
Roosie
Aug 9, 2015 07:37 AM
