7.2k rev limiter......
Old May 13, 2006 | 11:06 PM
rstdave's Avatar
rstdave
Default 7.2k rev limiter......
Wanna raise the rev limiter to 7.2k and was wonderin what's actually involved to do this/costs???? I'm on solid lifters and it pulls really hard to the limiter meaning it keeps hittin the limiter in the lower gears especially! Cheers
Old May 14, 2006 | 02:56 AM
GazzaG's Avatar
GazzaG
Don't think you can mate
Old May 14, 2006 | 03:45 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
The fuel ECU controls the rev limmit, you need to change some resistors, i dont know which or what for afaik!
Old May 14, 2006 | 10:13 AM
Rick's Avatar
Rick
actually it's capacitors...
the other way is to swap to an s1 fuel ecu, and rewire the TPS
Old May 14, 2006 | 10:48 AM
KSA-Cossie's Avatar
KSA-Cossie
I did this on my old s2 got tony from turbosystems to do it.
Old May 14, 2006 | 08:02 PM
Hrsturbo's Avatar
Hrsturbo
so a S1 fuel ecu will let you rev to 7.2k or does it remove the limit?
so is this a straight swap? how do you mean rewire the tps?
Old May 14, 2006 | 08:18 PM
Rick's Avatar
Rick
It will remove the rev limit totally. I use an OMEX limiter which is adjustable, and gives u either a hard or soft limiter. It makes the car much quicker to launch, as u can bounce off the limiter without the car bogging down.
if you simply swap the sw for an s2 item, u will have no full throttle enrichment, or fuel cut on closed throttle.
Instead of the TPS earth wire going to earth, it needs to go to a terminal on the S1 ECU - essentially it's -ve switching. I worked this out years ago - never understood why more people didn't do it. Can't remember the pin no from memory.
Old May 14, 2006 | 09:13 PM
SafeChav's Avatar
SafeChav
According to the info i have from the Bosch manual Fuel cut is a standard feature of the KE Jetronic???
Old May 14, 2006 | 09:34 PM
DazC's Avatar
DazC
Yes it is but if you swap the S2 box for an S1 box, the wiring will be configured wrong for the S1 box making the Decel fuel cut off feature inoperable!
Old May 14, 2006 | 10:42 PM
Rick's Avatar
Rick
Mr chav - which fuel cut are u reffering too?
I'll be most happy to educate u
Old May 14, 2006 | 10:44 PM
SafeChav's Avatar
SafeChav
The overrun cut off that the fuelling ecu does as part of its miraculous (!!!??) fuel saving economy.
I am more than happy to be educated
And stop ignoring me on MSN ya c*oont
Old May 14, 2006 | 11:15 PM
Rick's Avatar
Rick
I'm not - i post from diff pc's and my home pc is always signed in - if im there - i'll reply - ignorance is a sign of weak character.
The overun fuel cut IS built into every ECU - but have u considered how the ECU knows u are on overun?
Old May 14, 2006 | 11:19 PM
SafeChav's Avatar
SafeChav
Ive just had a look over the wiring diagram and i see the wiring variation, pin 6. Series 2's dont have the connection on pin 6 instead its in with a common ground.
Old May 14, 2006 | 11:21 PM
Rick's Avatar
Rick
THe problem is that u there is no pin in the S2 multiplug. Call me a butcher, but i soldered a wire directly to the ecu pin. It's done 2 years and 40k with no probs
Old May 16, 2006 | 11:14 AM
C14KEE's Avatar
C14KEE
so does this mean theres no way of raising the limiter on a S2?
Id be interested to know how if you could, 7.2 K sounds nice.
Old May 16, 2006 | 11:20 AM
SafeChav's Avatar
SafeChav
There are capacitors you can change inside a S2 fuelling ECU although capacitors have massive tolerances, and its not something i would advise doing as a DIY job just incase.....
Old May 16, 2006 | 11:57 AM
C14KEE's Avatar
C14KEE
so thats the only way?
id be interested at whatever cost......GoTech?
Old May 16, 2006 | 12:10 PM
SafeChav's Avatar
SafeChav
After market management is always going to better than KE Jetronic, just the question of can you afford it?
Old May 16, 2006 | 01:01 PM
C14KEE's Avatar
C14KEE
moneys no object for my machine
whats my options on aftermarket management?
Names and prices by any chance?
and this might be a stupid question, but getin back to the point, will aftermarket management able me to raise the limiter?
Old May 16, 2006 | 01:03 PM
SafeChav's Avatar
SafeChav
With good aftermarket management and a DEEP pocket the sky is the limit.
I don't know much about aftermarket management im still a standard RS boy
Omex is one they're only up the road from me aswell!!
Old May 16, 2006 | 01:09 PM
C14KEE's Avatar
C14KEE
any idea on the price?
cheers for the reply mate
also could u look at my other thread? cossie calipers? noone seems to answer. maybe you will know.
Old May 16, 2006 | 01:14 PM
SafeChav's Avatar
SafeChav
I have no idea on price, people like Rick, DazC, Biglee etc will know a hell of a lot more than me
Your other thread christ sake dont want much do you
Old May 16, 2006 | 06:00 PM
C14KEE's Avatar
C14KEE
haha am i asking a bit much???
Old May 16, 2006 | 06:14 PM
notSteveS2's Avatar
notSteveS2
cosworth management is the route i took...
for all prices and queries get on the site...
www.oddkiddcreations.co.uk
Old May 16, 2006 | 06:47 PM
C14KEE's Avatar
C14KEE
not sure about cosworth management.....
Seen a nice big arguement on here before about people criticising how old the system was.....
What sort of price is it for the cossie stuff then?
Old May 16, 2006 | 07:31 PM
SafeChav's Avatar
SafeChav
Indeed Cossie management is stone age now, and aftermarket managements are getting a lot cheaper. Cossie stuff was the stuff to have when it was a lot cheaper.
Old May 16, 2006 | 07:32 PM
notSteveS2's Avatar
notSteveS2
click the site link for prices etc matey...
it may b old but proven!!!
Old May 16, 2006 | 07:44 PM
SafeChav's Avatar
SafeChav
I never said it wasn't proven.......
Old May 16, 2006 | 08:33 PM
C14KEE's Avatar
C14KEE
yea but i cant see the prices on the site!
Old May 16, 2006 | 08:34 PM
SafeChav's Avatar
SafeChav
Which site is that mate? Im surprised the regulars havent been along yet to give their opinions on after markets ecu's.
Get some phone numbers and ring round
Old May 16, 2006 | 08:45 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
I can raise the Rev Limit on the KE Setup @ 500 revs extra per time
As said the best VALUE FOR MONEY WITH RESULTS is weber management (Cosworth) As the parts costs naff all and work 100%
Old May 16, 2006 | 09:08 PM
C14KEE's Avatar
C14KEE
how much would i be looking at Mr Oddkidd?
Old May 16, 2006 | 09:09 PM
Versus_Creations
Ask me a question!
Cant offer services via here mate
Old May 17, 2006 | 05:24 PM
notSteveS2's Avatar
notSteveS2
register on the site geez.... all u need to now and more!!!
well worth doin......!!
Old May 17, 2006 | 09:35 PM
DazC's Avatar
DazC
Hang on a minute!! We have all assumed he was on about an S2. If it's an S1 then it's different!
Old May 17, 2006 | 09:36 PM
Rick's Avatar
Rick
sledge hammer, walnut...
SafeChav's Avatar
SafeChav
A valid point
(note the S2 in the siggy)
Old May 17, 2006 | 09:39 PM
DazC's Avatar
DazC
A valid point
That is why we assumed it's for an S2. It may not have been as not all people put their own cars in their siggy...
Old May 17, 2006 | 09:42 PM
SafeChav's Avatar
SafeChav
A valid point
Yeah thats a fair comment i was only playing
Im pretty sure he does have from talking to him on previous threads
As they say assumption is a mother fucker though
Old May 18, 2006 | 10:58 AM
C14KEE's Avatar
C14KEE
its a series 2
