What company were doing the ign leads at last year shows
There was a small company doing 8mm and 10mm ignition leads at all the shows last year, can anyone remeber what they were called.
It was a small company not like magnacor e.t.c
Not as easy as that, look at my signature and you see i dont run a cossie or RST.
The standard ford leads are red and im after blue.
If not its magnecor 8mm ones.
I wanted some better sheildedas i knocking leads out in under 3000 miles as they get cooked due to how they sit in the head
