SOLDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
...A motorsport plate that you put on a std 4x4 front diff to beef it up
No bolts included (You take the bottom of the diff off and put this plate on then put the bottom back on so you need longer bolts)...suposedly cures the weak front diff case
25 uk pounds delivered
