Bleeding the brakes. Esc cos (Harry AP 6 Potters)
i did this last night, just need to check
i bled the fronts (2 nipples per caliper)with the ignition off... thats the way yes
i havent bled the rears yet.. how is this done?
cheers
Dave
cheers
Dave
ignition on undo the nipple on rear caliper and press the brake pedal on 5sec's a time or it cause some sort of problems with the pump.
cheers
Daniel
cheers
Daniel
I Pretty sure your suppose to do the rears first.
Wot happened with you wanting SRF fluid off me
.Take it you dont want it now.
Would of been nice for you to tell me of this
excuse me..... i did ask you to send me your bank details..
pm me your bank details you welsh spaz
https://passionford.com/forum/viewto...&highlight=srf
unless you were going to send them to me for free!
sorry, i dont have time to fuck around at the mo, you didnt reply OR send me a PM as requested
so take your arsyness and your '
' and
I did send you a PM.And i just checked and i cleaned up my messages and deleted it from the sent box.
So i cant prove it.
Why didnt you pm me if you were that desperate.
So i cant prove it.Why didnt you pm me if you were that desperate.
So i cant prove it.
So i cant prove it.what a coincedence!
i see no pm from you and i never delete them
so quit making out that i wasted your time, i asked.. you never replied. Simple as
i went elsewhere
like i said , i dont have time to fuck around at the mo
too bad eugene
Where have i said you wasted my time
.I simply said you could of Pm'd me either for my bank details (Whhich i did send.Honestly Officer
)Or to find out wot was happening as you were so desperate.Are we gonna start fighting over this then bring it on.
Originally Posted by whitneyd
What is he on about with the ignition?? I've never heard about this.
so in steps for the rear
1) open nipple
2) pump pedal a few times
3) switch on ign
4) wait for fluid to purge and then close nipple
(dont let pump operate for more than 5-10 secs to avoid over heating it)
1) open nipple
3) switch on ign
nah ignition on, open nipple, press pedal 5 secs. fluid will ony come out when the pedal is pressed
if you changing the fluid do the fronts first as this gets all the fluid out.
cheers
Daniel
cheers
Daniel
bleed front left
bleed fornt right
open rear left nipple
push foot brake FULL travel
switch IGN ON
allow fluid to flow till all air escapes
close nipple
release brake pedal andwait until hydraulic pump has stopped
press foot brake to HALF travel keep here
open right rear nipple
allow fuid to flow till all air escaped
close nipple
bleed fornt right
switch IGN ON
close nipple
close nipple
