Was on the rolling road today
Got the car serviced the other day and thought it would be best to get it checked on the rollers before i start doing loads of miles on it.
They ran it up on the rollers and it made 190@ the wheels with 14.5 psi, slightly down on boost so they turned it up a little and tried again.
It then made 196.5@ the wheels with 16.4 psi, its down 8.5bhp since last year which is due to the fact its 23deg outside and the car was on the rollers for 1 + 1/2 hours.
Looking at the old graph its very similar but just down a bit top end, the ACT is 7 deg up from the last time.
CLICK HERE FOR THE GRAPH
Originally Posted by s6 turbo
very nice mate, how much roughly does it cost for dyno tunning??
cheers
cheers
Originally Posted by notSteveS2
how much that at flywheel?
Originally Posted by Lemon S2
What spec are you running if you don't mind me asking?
looks a clean car
looks a clean car
1618cc CVH, stage 2 big valve head (ported and polished), Newman cam, solid lifters, piper vernier, wire ringed block, lowered compression(7.5:1), ARP conrod Bolts, heavy duty bearings, high pressure oil pump, AVA ecu, 7000rpm limiter, AVA modified fuel system, AVA high flow tubular manifold, T28 turbo, 360 bearing, reshaped cosworth front pipe, AVA Large capacity intercooler, samco water and boost hoses, magnecor leads, magnex exhaust, modified airbox, AP 4 paddle clutch
do engine advantages have a web site? if not can i have the number please
cheers
cheers
looks a clean car
looks a clean car
full credit to you
Originally Posted by DanS
I think the power @ wheels gives a better indication than at @ fly - more reliable anyway
Good figures for just over a bar of boost mate nice one!!
Cars looking sweet!!!
Cars looking sweet!!! Joined: May 2003
Cars looking sweet!!! By compensating as you suggest. The only meaningful figure. Power @wheels would then become a mere guestimate along with projected @fly figs.
Are you not aware of pressure variations according to height above sea-level and runs that take place in different ambient temperature conditions?
Even at AVA's god-given RR, the weather is subject to variation.
Originally Posted by safechav
This is getting a bit technical now
Different heights above sea level mean different ambient pressure levels, this affects performance etc. Do some research on the Pikes Peak events and see what is said about the differences when the car is going through the ascent.
But, easier to understand is the climate differences. We all know how much better our cars are on cold days. Now carry this across to the Rolling Road. Modern RR software can compensate for differences in temperature and provide a reading that is more standardised.
Imagine running your car on a Rolling Road in Scotland in winter, then running it on EXACTLY the same Rolling Road but in Cornwall in summer. There is no way that the Power-at-wheels figures would agree!! How could they?
Make sense now??
if you look at davies past 4 graphs theres only been a 10bhp difference at different times of the year
in summer there fans are pumping out that much cool air your actually feelin cold standing at the entrance,in winter there fans are not needed to do as much hard work,you will get some difference in temps in winter coz of the denser air
anyway rr figures are no good unless the car has been built and tested on the same rr which davies has so all in all he'll be a happy man,its an indication for him as to how well his engine is running and how it compares to other cars been rr one there rollers,and i would say thats good considering some of the allegedly 250-280bhp cars ive seen rr there that dont do what he's doin at the wheels,roll on winter again for the more exagerated bhp figures
also davie runs this boost all year round not just for rr shootouts
Ive had a good chat with Allan with regards the above, If you have any specific questions you want answered or any aspect your unclear of then he is more than happy to comment.
Maybee a 'nice power' 'cars looking well' comment would have been more appropriate, but NO! instead you appear to have a snide dig at AVA. Seriously Christian whats that all about?
Cars looking sweet!!! Andy, in NO WAY was that a dig at AVA specifically. I just wanted to point out that while power at the wheels is in many way the most reliable figure, there are still variables involved and they are quite significant.
Every other RR apart from, it would appear, AVA's has the ability to compensate for pressure and temperature to an industry recognised standardisation. Take Dyno Dynamics for example, their system is intended so that you can run a car on any Dyno Dynamics Dyno anywhere in the world and produce a graph that makes some sense from a comparison point-of-view.
OK, sorry Dave for not saying anthing about the car, I have always had respect for your car as I like to see things done differently and yours certainly is! I just got side-tracked!
IMO theres no substitute for winter conditions.
