warm runnings......
Old May 11, 2006 | 11:58 AM
gingeRS's Avatar
gingeRS
Default warm runnings......
boticed my cossie runs very warn when i'm using it.
about to fit new coolant hoses (shiny new roose jobbies) and was wondering if it was worth replacing the thermostat whil i'm at it.
its a 92 saff 4x4. what do these thermostats cost and are they hard to fit, where on the engine are they located?
will be flushing the system and running on 50/50 antifreeze/water
any advice apreciated
rory
Old May 11, 2006 | 09:08 PM
Daveesaunders's Avatar
Daveesaunders
Probably wouldn't hurt to change the thermostat just of piece of mind, you may want to flush the block and rad out while you've got the pipes off.
Old May 12, 2006 | 06:42 AM
gingeRS's Avatar
gingeRS
this was the plan, just wondering where the thermostat is located, and how much they cost??
flushing the rad and block is on the to do list too.
Old May 12, 2006 | 06:45 AM
infinityMJD's Avatar
infinityMJD
end of the day, at the cost of a thermosstat why not!!! allso temp sender might be worth swappin out!!! if your doin the cooling system migth as well do the whole lot!!!
Not sure how much the thermostat housing is for an rs500 but for most cars its cheap as chips so another one to add to the trolly me thinks
Old May 12, 2006 | 11:53 AM
gingeRS's Avatar
gingeRS
dont think i'll bother chaniging the housing
new sensors is on the cards sometime in the near future too
from the other thread it seems a new thermostat can be had from halfords for about a tenner
Old May 12, 2006 | 10:38 PM
infinityMJD
sounds bout right for halforda, must be a gmf round your way???? or some other local buisness, there normaly about 10% less
Old May 17, 2006 | 07:44 PM
charlie luciano's Avatar
charlie luciano
Default 4x4 stats
Whatever you do don't put a stat in the car for a tenner, get yourself one from ford their about Ł40, while its out drill a small 2-3 mm hole in it because 4x4 stats are notourious from jamming shut, doing this will help if the stat ever jams shut by letting the coolant through, don't ever run a 4x4 cossie without a stat in place, stat housing is i think still available from ford front bit around Ł45 and back piece a bit more cost at around Ł140, changed mine recently, can't get the little bleed screw that sits in the front stat housing though so if yours strips its thread replace with a like item.
C L
Old May 17, 2006 | 07:52 PM
trevCOSS's Avatar
trevCOSS
I suspect its the thermostat not fully opening causing it to run hot, had two do it on mine, as stated get one from ford or woodford, I think MSD also does them at a resonable price, to be honest I dont think you will get the 4x4 one from halfords etc anyway. Good luck.
Old May 18, 2006 | 06:35 AM
gingeRS's Avatar
gingeRS
so fords (woodford or msd) it is then
cheers guys
will drill the thermostat as thats what we do here at work, prevents airlocks and allows the systenm to bleed a little quicker
cossie362
Oct 11, 2015 03:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
pabloXR
Sep 21, 2015 12:42 PM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
